Diesel Leak
/ Diesel Leak #1
HinoBill
Hinomoto N189
I have a Hinomoto N189 (Toyosha engine) that has started leaking diesel. It looks like it may be a gasket but not sure. Any help would be appreciated re: source of leak, difficulty of self-repair and/or name of good diesel mechanic (willing to work on grey market tractors) in Seattle/Tacoma area. The dealer I bought from is good, but clear across the state.
Also, I am looking for any available manuals for the N189.
Thanks.
/ Diesel Leak #2
It would appear that your leak is on the high pressure side of the fuel pump . If it was on the low pressure side you would have air in the fuel causing a "spongy" feel on the fuel pedal . If you can slightly pinch the return line to the tank while the engine is running the leak should reveal itself with a steady stream squirting out . Good luck .
/ Diesel Leak
Thanks- I will check that out!
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2003 Kenworth T800 Log Truck (A62679)
2003 Kenworth T800...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A65053)
2026 DEVELON...
2013 PETERBILT 365(INOPERABLE) (A65643)
2013 PETERBILT...
Accu-Line 110V Tire Changer (A64556)
Accu-Line 110V...
White 5100 12R Planter (A66285)
White 5100 12R...
