Diesel Leak
/ Diesel Leak #1
HinoBill
Hinomoto N189
I have a Hinomoto N189 (Toyosha engine) that has started leaking diesel. It looks like it may be a gasket but not sure. Any help would be appreciated re: source of leak, difficulty of self-repair and/or name of good diesel mechanic (willing to work on grey market tractors) in Seattle/Tacoma area. The dealer I bought from is good, but clear across the state.
Also, I am looking for any available manuals for the N189.
Thanks.
/ Diesel Leak #2
It would appear that your leak is on the high pressure side of the fuel pump . If it was on the low pressure side you would have air in the fuel causing a "spongy" feel on the fuel pedal . If you can slightly pinch the return line to the tank while the engine is running the leak should reveal itself with a steady stream squirting out . Good luck .
/ Diesel Leak
Thanks- I will check that out!
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
Warren Power...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
1980 19ft Sailboat w/ 2018 Continental Trailer S/A Boat Trailer (A64557)
1980 19ft Sailboat...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A64557)
2005 Freightliner...
