Oil & Fuel Diesel jelling?
/ Diesel jelling? #11
I use the additive all year around as it is also an injector cleaner so I figured it couldn't hurt. I haven't seen any problems in the year I've had mine.
/ Diesel jelling? #12
#2 diesel fuel (summer) kind of starts to gel at 28 degrees, but is not a noticable issue until around 10 degrees F.
Straight #1 diesel (winter) will go to well below zero F before causing problems - depends on the additive package exactly how low it will go. Many 'winter blends' are a combo of #1 & #2 & an additive.....
If you get to regular temps of 10 below for a high, you will be many dollars & time ahead getting a block heater & plugging your tractor in for an hour or 2 before starting it. This is good advise if the temp gets much below 20F really - just easier on the engine.
You will need a good strong battery. You will need a new fuel filter in fall. You will need to use an additive like Power Service. You will need a good winter oil, at much below zero you will be thinking a good synthetic. You might want synthetic in the tranny/hydro system as well. Thick oils are a real issue at 20 below F.
Oh, the important part: Use the additive before you need it! Start using it when it's 35 outside, so it gets mixed into your fuel. Once the temp is -15, it's too late to pour it in the tank - you needed it mixed in ahead of the zero temps.
Ether can help in starting an engine, but it is very hard on diesels - it does not create a burn like diesel, but a shocking explosion on the piston. It also can create problems with some preheaters.....
During hot weather, #1 diesel fuel is not so good. It is lower in power per gallon, and it does not lubricate the engine & pump as well. Anti-gel additives are probably ok in lesser amounts over the summer.
I farm with 3 diesel tractors in Minnesota. This is based on my learning curve, and the bulk fuels I get. We got to -28F this winter a few mornings. Typically it got up to -10 during the day, and this was only a couple of times. Usually weather of 0 - 25 F is not too big of an issue for your tractor, and I bet that is a more typical winter day for you. /forums/images/graemlins/smile.gif
--->Paul
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
2005 John Deere 7320 (A60462)
2005 John Deere...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
(INOP) 2008 JOHN DEERE 160D LC EXCAVATOR (A59823)
(INOP) 2008 JOHN...
2021 Caterpillar 299D3 (A60462)
2021 Caterpillar...
