Designing a bin tipper, sizing hydraulics.
   / Designing a bin tipper, sizing hydraulics.
Also, Seeing that it has dual cylinders, would I need to worry about balancing the two of them so they extend at the same rate?
   / Designing a bin tipper, sizing hydraulics. #22
The dumper frame would keep the cylinders in phase, and as for the pivots, either would work fine. The bearings will require a lot less maintenance , were the pin bushing set up will require a lot more greasing and be a bit messy.
   / Designing a bin tipper, sizing hydraulics. #23
Good advice. . Plus depending on where you are a food safe grade grease would prob need to be used.
Oenophile's shun greasy wines. Probably why wines are rarely paired with french fries.
   / Designing a bin tipper, sizing hydraulics. #24
Food safe grease and hydraulic fluid would probably be a good choice...
Aaron Z
Yeah good point on the messy / mantinence factor on the pin bushings. Pillow block for the win. I do feel like I might stick with the single cylinder in the middle. Feels like less overall complication of the design for me. That is unless anyone has a good reason to go double. I see both ways in the commercial versions. Those reference pics also feel like they are a good reference for burly factor / metal sizing / probably a bit more burly than I need to go.
   / Designing a bin tipper, sizing hydraulics. #26
As a point of reference the dumper I sent photos of would be typically used for a bin gross weight of 1000 pounds.
Depending on moisture content of your grapes (or how deep you load your bin) I suppose you could use a central mounted single cylinder. Personally I would use two for the greater lift capacity for possible different applications and (or) resale.
   / Designing a bin tipper, sizing hydraulics. #27
He doesn’t want to use forklift to lift it.
The ones I'm talking about are not for a forklift. Pretty hard to get a forklift into a 36in door in construction sites. Something like this and maybe raise it up higher Screenshot_20180720-195238_Google.jpeg
   / Designing a bin tipper, sizing hydraulics. #28
Those can only dump on the ground or over a ledge.
yeah i definitely need the lift height so the auto tippers like that wont work form me. I guess for the single i need to calculate how big a cylinder i need. Typically a bin will weight 800-1100 pounds. so that lift you referenced is right in my range.
   / Designing a bin tipper, sizing hydraulics. #30
Are you guys not reading my posts much? Like my last one said (#27) last sentence. Lift it up higher.
2015 KOMATSU WA270-7 WHEEL LOADER (A60429)
2015 KOMATSU...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2013 JOHN DEERE 772G MOTORGRADER (A60429)
2013 JOHN DEERE...
Rooster Weathervane (A59231)
Rooster...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
