Deere 3203 Flashers
/ Deere 3203 Flashers #1
LBA1999
John Deere 3203
I have a 2006 3203 with close to 400 hours on it. My son left the factory warning flashers on until the battery was dead. After charging the battery, the flashers will not work and the hour meter is out. I looked at the parts diagram and talked to my local dealer mechanic. There is no listing for a flasher module in the parts diagram. Ideas?
/ Deere 3203 Flashers #2
Did you check all your fuses?
/ Deere 3203 Flashers #3
they're usually made into the headlamp switch
We checked all of the fuses twice. The headlamps and work lights work fine. It has a left/right turn signal switch also. Any idea how it relates to hour meter going out?
Thanks! That is more than I have seen anywhere! I will dig into my tractor this afternoon. I see the diode listed with the Wiring harness for my tractor, but no picture. The post you referred me to will really help.
/ Deere 3203 Flashers #7
In my case, the hazard and directional lights stopped working. I don't think my hour meter stopped working, but I'm not sure.
Good luck, let us know when you get it fixed.
/ Deere 3203 Flashers #8
Were you able to locate problem, I am working with a friend with similar problem.
/ Deere 3203 Flashers #9
Al
:welcome: to TBN
The original poster hasn't been active for about 7 years, so you may "wake him up" by sending a PM which will go to his email.
His solution would be interesting to know for this thread.
Click his user name and there will be a place to PM. Otherwise, another member may jump in to help..
What have you been able to decipher thus far?
I presume you already read the linked thread mentioned by "chipsndust"
https://www.tractorbynet.com/forums...305-diode-replacement-hazard-directional.html
John Deere 1025R (A62177)
John Deere 1025R...
2005 Ford F-150 Ext Cab Pickup Truck (A61573)
2005 Ford F-150...
2020 ATLAS 2 POST AUTOMOTIVE LIFT (A59912)
2020 ATLAS 2 POST...
2014 International Durastar 4300 S/A Dump Truck (A61573)
2014 International...
Schulte XH1500 15ft. Batwing Rotary Brush Cutter Tractor Attachment (A61572)
Schulte XH1500...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63688)
2017 Cadillac...
