Day Time Running Lights!
/ Day Time Running Lights! #61
I have no problem with them either. Just stating GM trucks seem to be the only ones running them.
Chris
My Isuzu NPR has them--but GMC and Isuzu are bedmates;)
/ Day Time Running Lights! #62
I'm in Canada, almost all drl's here now except motorcycles seem to like to disable their lights, which sucks since they are hard to see anyways. Drives me nuts in the US on 2 lane roads, it will be a gray drizzling day near dusk, and people won't turn their lights on, can barely see them coming when pulling out. I'm not sure how old people can see them.
/ Day Time Running Lights! #63
I can't remember seeing a motorcycle with the lights disabled, except for police bikes.
/ Day Time Running Lights! #64
I've never seen motorcycle headlights disabled. Motorcycles have have had the headlight come on with the ignition since 1971 and riders have the most to lose if they're "not seen". I can only see the one percenters doing this to defy authority.
/ Day Time Running Lights! #65
Used to think? If I drove slow enough, I could likely drive in snow with racing slicks. It may be difficult to comprehend, but driving the speed limit isn't always needed to get from point A to point B.
Im sure glad a don't have to drive behind you when going to work. :)
/ Day Time Running Lights! #66
Chris
Honda Ridgelines have DRLs, on while the engine is running and for a little bit after it is shut off.
/ Day Time Running Lights! #67
I think that DRL's are the best thing since sliced bread.... mandatory in the States is OK with me. I even put the circuits in my non-GM vehicles... ANOTHER THING them Canucks do right..... eh? :)
I'm neither for them nor against them (much), but they do reduce fuel mileage enough so that manufacturers can pretend, for CAFE requirements in the USA, that their cars and light trucks don't have them.
/ Day Time Running Lights! #68
For DRL use the lights run through a dimmer circuit so as not to put much of a drain on the alternator. Lacing the gas with ethanol probably reduces fuel mileage a lot more.
/ Day Time Running Lights! #69
I had a 1974 Yamaha RD200 with a light switch, so it was definitely after that. As for lights out in modern times, I see Harleys with no headlight on on a regular basis. I'd say about 1 out of 20 Harleys I pass have no headlight on. I don't know if they added a light switch or if Harleys still have them, but it certainly makes them near invisible in the shade. Lucky for them you can hear them from 5 miles away with their obnoxious straight pipes. :rolleyes:
You're likely right on that one. My friends all say I drive like an old man. I'm never in a hurry. I rid my life of the rat race and improved my time management about 7-8 years ago. Been a great change in my life, and has saved me plenty in fines and insurance costs to boot. My insurance company even sent me a "Safe Driver" certificate (which I thought was cute). As a side benefit, when going somewhere with friends, they tend to drive because they still have rockets up their butts. :)
The fuel costs are negligible, less than 1%. It is estimated if DRL were mandated across the US, it would add 2 million gallons to the US fuel bill, about 1 penny per person. Of course, this is just another "every penny adds up" example. With thousands of laws per state and tens (hundreds?) of thousands of federal mandates, a penny per year quickly becomes a part time job of extra taxes for little to no returns.
/ Day Time Running Lights! #70
Yeah, I could be mistaken on exactly when motorcycles first automatically had headlights on all the time and likely varied between stated and countries. I just did it out of self-preservation. But Harley riders (and wannabes with Harley look-alikes) are a different breed. There are choppers with 1930s style girder forks and many of indeterminate vintage which may escape the law.
/ Day Time Running Lights! #71
I do not think that DRL's effect fuel milage any more than driving down the road with a bug splattered windshield and the very little wind resistance that would cause. And, you would be hard pressed to measure the fuel mileage difference between two identical vehicles, one with DRL's and the other sans DRL's... The reason the other companies did not go to DRL's is 'content' cost.... each penny or part of a penny they can deduct from every vehicle that comes down the production line... [ I want my vent windows back...!!!!! ] :)
/ Day Time Running Lights! #72
DRL help spotting cars in low light areas ,when the car is coming at you..
MY problem with DRL where are the tail lights.. Dumbest think. WHY NOT have the tail lights burn at a differnent brightness. How many times have you been driving down the road in a pouring rain,fog, or white out. A car passes you with only there DRL ,(yes state law to have headlights on and there not) and pulls in front of you and you can not see the back of there car.
So my point is have DRL and tailight to come on at the same time... I feel this would make driving a lot saver being able to see the rear of a vehicle in a downpour or fog.. Yes it might only be a split second sooner seeing that lead vehicle but at least you had that split second .
/ Day Time Running Lights! #73
Yeah, I think some manufacturers just did the minimum to comply with the letter of the law, not the spirit. My Volvo has all lights, headlights and taillights, on at full brightness whenever the engine is running. I don't even have to remember to turn my lights on at dusk. The only way I know I haven't turned the lights on is looking at the switch or using the dimmer switch, when the headlights flash instead of toggling high or low beam.
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2022 Peterbilt 567...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
UNUSED WOLVERINE HYD MINI 4IN1 BUCKET (A64281)
UNUSED WOLVERINE...
