damaged backhoe stabilizing piston
/ damaged backhoe stabilizing piston #1
badge142
The other day I dropped, I mean some idiot dropped a rock on my stabilizing piston arm scratching the chromed area about 6" from the foot plate. TC24 with backhoe. No other damage other than a few gouges not to bad.
Any ideas on the best way to repair
/ damaged backhoe stabilizing piston #2
How bad are the scratches? If not too bad, I've sanded them out with emery cloth and run with them for years. It all depends if the seals leak. If you do sand them out, wipe off with a oily rag to mage sure you get all the grit and metal particles of the cylinder.
If not, you'll either have to replace the cylinder or rod and rebuild the cylinder. It might be a good time to consider installing cylinder guards. I have them on my Woods 1050 and previously on my New Holland 758 and they got quite a few dents from stones with never any damage to cylinders.
Andy
/ damaged backhoe stabilizing piston #3
BTW, the cylinder guads are pieces of channel iron that are about as long as the cylinder with have holes to be pinned to the lower cylinder pin. The upper end just lays on the cylinder and floats with it.
Andy
Thanks Should I sand them smooth or just so the rough edges are gone? They are not to deep.
/ damaged backhoe stabilizing piston #5
Dan, I'm in total agreement with Andy. If the scratches are not leaking fluid, simple sanding (use emory paper or similar grit, 400 to 600 grit). If the scratches are deep enough that you are leaking fluid, you will want to remove the entire cylinder and take it to a hydraulic shop. They can swap out the piston and it will save you from having to buy an entire new cylinder.
Thanks guys, sounds simple enough.
/ damaged backhoe stabilizing piston #7
It's so simple Rico304 could even do it, if you give him enough time ;)
/ damaged backhoe stabilizing piston #8
If you have gouges and they are causing leaks, you can fill them with JB Weld (or is it JD Weld?). I banged up a cylinder on my hoe a long time ago and the cylinger was leaking pretty bad as a result. Following a tip from TBN, I filled the gouges and smoothed off with emory cloth, and it's been working great ever since.
/ damaged backhoe stabilizing piston #9
Wow, it must be a pretty uncomplicated job! Thanks so much Bob. I feel really good about myself now :)
/ damaged backhoe stabilizing piston #10
Sanding will take off the high spots, but it will also take off some areas you don't want removed. When you sand, you will give a perfectly round rod flat spots.
Instead of sanding, use a fine file. Just take off the high parts and ignore the lowspots. Take your time and keep the file flat to the surface of the cylinder rod. There will be some pits, or depressions from the damage that will remain. Leave them alone. Short of welding and machining, they are just something you'll come to live with.
The seals on your gland that the cylinder rod slides through are wide enough that there shouldn't be any leakage. The only time you could possible have leakage is when the pitted area passes throught the seals inside your gland. If it did leak, it would only be a drop or two.
Sanding away too much will cause you much more problems than leaving the pits in the cylinder. The unround shape will cause wear on your seals and lead to them wearing out sooner than they should.
Eddie
/ damaged backhoe stabilizing piston #11
File it flat, clean with carb spray, flux the heck out of it, lay some silver solder in there, file flat again.. polish with 1000 or 2000 paper.. and go.
Fully extend cyl.. so solder area is not near seal/wipe. it is is near seal/wipe, lay a wet hand rag on the seal/wipe.
Soundguy
/ damaged backhoe stabilizing piston #12
On our bikes front ends, we use super glue to fill in particularly deep gouges that leak (after file / emery cloth)
/ damaged backhoe stabilizing piston #13
When that stuff flakes off in the cyl.. it will be just like any other foreign mattert hat you don't want circulating in the system.. plugging screens, holding relief valves open.. etc.
Goops are not the fix for hyd systems. Even stuff like 'paint' on a piston contaminates the oil.
Soldering it with silver solder, or brass.. or replacing the piston is the real answer.
Soundguy
/ damaged backhoe stabilizing piston #14
Andy
Great idea on the guards. I guess I should make some. Have a
pix for show-and-tell?
/ damaged backhoe stabilizing piston #15
Use a fine file to take off any high spots that might tear the seals, then try it. Should only leak (if it does) when raising the landing gear. If it leaks too badly have it rebuilt, an amateur machinest trying to DIY with silver solder will probably wind up with a cylinder that requires a cylinder shop to fix IMHO. On mine I live with a few drops of leakage as I am in rock all the time.(I even have a spare hose on hand after snapping a fitting or two back in the bush and trying to figure out how to raise the gear to drive home)
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
2013 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2013 Peterbilt 567...
New/Unused Quick Attach Double Hay Spear (A61166)
New/Unused Quick...
New/Unused Agrotk YC-32G Sawmill (A61166)
New/Unused Agrotk...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
