D-ring mounting angle
/ D-ring mounting angle
Why bother? Just hook the chain or binder on the inside edge of the pad, 4 corners..done, unless Texas requires one on the blade
Actually they require a chain on the blade and ripper. So it takes 6 chains total.
Hooking to the tracks works that is how I secured it when I brought it home but I don't really like that method, especially on smaller dozers like this as I can see the track deforming as I crank it down. Also I have to fully tilt the blade to get it under 102" on the trailer which puts the blade right in the way of where one of the front pad attached chain runs. The D-rings won't take much time at all to install and will make things easier.
/ D-ring mounting angle #12
I always like them opposite of how the pic shows. Seems to be a more pure pull if that makes sense. Northern tool has some good ones along with tractor supply. I recommend the suitcase welder for this
Brett
/ D-ring mounting angle #13
Angled would probably be a bit stronger but as pointed out more likely to grab roots and limbs so as the picture shows would be my choice.
/ D-ring mounting angle #14
Thanks for explaining, hope this approach works out for you
2007 Volvo VNL Truck Tractor (A61307)
2007 Volvo VNL...
2020 Deere 50G (A53317)
2020 Deere 50G...
2009 Ford F-150 Crew Cab Pickup Truck (A59230)
2009 Ford F-150...
TANK MANIFOLD (A58216)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
