D-ring mounting angle
/ D-ring mounting angle #1
bdog
Elite Member
Texas
John Deere 6130M
I am going to weld some D-rings like this on my dozer to make chaining it down easier. I have the same model dozer as the one pictured and there is a company that puts rings like this on them but I will be doing it myself. I figure it will be a good project to learn how to use my harbor freight 110v wire welder I got for Christmas.
The chains attaching it to the trailer will be going out and down at an approximate 45 degree angle to the front and back.
Should I just mount the rings as pictured or would it be better to mount them at a 45 degree angle? The d rings obviously pivot but if mounted horizontally but pulling forward or backward seems like it would want to twist them. The ones I got are 1” and rated for something like 30k each which is more than the whole machine weighs so I doubt I will hurt them but it seems like they would be stronger and put less stress on the welds if oriented correctly with the load.
/ D-ring mounting angle #2
I'm no certified welder by any means, but I'd not even attempt that heavy of iron w/ a 110V HF welder, IMHO you're gonna hit the duty cycle trip a lot, and likely not get sufficient penetration.
Given the discussions going on safe load restraint, do you really want to risk that on a light duty hobby welder? I hope not for others on the roads sake.
HF welders are great, I used one for years, but I also knew it's limits and something that heavy I'd only attempt w/ stick or a big boy MIG. Just my opinion, YMMV
/ D-ring mounting angle #3
For God's sake don't use that welder!:thumbdown::thumbdown::thumbdown::thumbdown: Have someone with a 220-volt welder do the welding.
I was kidding guys. I will be using my V350 Pro and either stick it with 7018 or use dual shield through my LN-25.
Curious about the angle though.
/ D-ring mounting angle #6
My thoughts on the angle, if you angle it it's gonna have some tendency to extend and fill w/ crud as it is expelled from the tracks, as in the pic it's gonna hang that way. As big as they are compared to load, I doubt it makes much difference strength wise, so I'd opt for as in the pic myself. Obviously, others believe as in the pic is acceptable, so don't re-invent the wheel.
And good to hear on welding.
/ D-ring mounting angle #7
I knew you had to be kidding!
/ D-ring mounting angle #8
Count me as another vote for stick with 7018, exactly like the picture.
/ D-ring mounting angle #9
I'm with you on this one. Hanging down is the best because otherwise they will catch on things and the strength is not an issue (If the welds are good - just kidding).
/ D-ring mounting angle #10
Why bother? Just hook the chain or binder on the inside edge of the pad, 4 corners..done, unless Texas requires one on the blade
2014 Chrysler 200 Sedan (A59231)
2014 Chrysler 200...
10' Container w/ Side Door (A60463)
10' Container w/...
2019 GALYEAN...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2021 Kubota SVL75-2 Track Loader (A61307)
2021 Kubota...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
