Custom hydraulic backhoe thumb
/ Custom hydraulic backhoe thumb #181
I have the Ansung model BH76 which is similar size to kb77 I think. From info I got here, I ordered from Surplus Center one that measures out to work to convert my thumb from manual to hydraulic. Item # 9-8760, '2.5x13.25x1.25 DA Hydraulic Cylinder' 159041 XHo411. Price was $70.
thank you ron50. i will check my length and stroke to see if its the same, should be.
my sister used to live around phoenix but now lives in payson, its a beautiful area out there.
/ Custom hydraulic backhoe thumb #182
Although it has a similar Yanmar engine as does the JD110, I don't see anything else it
might share with the Deere. It did compete in the same segment, smaller industrial TLBs.
AUX valves were optional, as I recall.
I knew the CBL40 has HST drive, and a 2-pump hoe, but doesn't the implement hyd pump
that powers the FEL also power the hoe?
I am not a fan of bolted-on thumbs, and esp not a hyd one with all that force at your
command.
As I pointed out near the beginning of this thread, I would get a welded cyl of the same
diameter as your bkt cyl, and design the thumb around it. That way, you do not have
to modify the cyl, and you can decide where to put the thumb pivot to achieve
the open/closed geometry you need. You have to fabricate a thumb anyway.
On that machine, I would use pivot pins of 1.5" diameter and 1/2" plate steel.
Another question, since you seem to have cornered the market on thumb fabrication...HAHA, what width is the thumb you settled on? The bucket on my hoe is 24" and suits most of what I needed. I was thinking 12" wide w/ 2 tines, or would you say to wide?
/ Custom hydraulic backhoe thumb #183
Ron50,
I also have the same backhoe, did you confirm that it's the right cylinder? I want to do the same setup on mine. Hopefully you can advise me as you progress?
/ Custom hydraulic backhoe thumb #184
Aquamoose,
Surplus Center just shipped yesterday for some reason. Due to me UPS this comming Monday. This should give cylinder and I already have a pressure relief valve from Ken's BoltOn Hooks to protect thumb from being over powered by curl function of bucket. I've used excavators that have this relief so for $100 I thought it was worth it. Pay now instead of repairing later.
I"m adding a valve to the control stack to power it. I'll split the stack between the stabilizer vlaves and insert the new one. This is the hardest part of the install to get the stabilizer valve. I hope tomorrow that with the help of a local hydraulic shop I'll get it done. Walvoil distribution center gave me three choices, just have to get it right. Then I'll get hoses made. No diverter or 3rd function, just another valve block. Ansung was nice but they never called back, so no help.
I'll keep you posted, Ron
/ Custom hydraulic backhoe thumb #185
maybe your not understanding me or I'm not understanding what you are trying to say.... i already have the bh77 back hoe with the factory kubota mechanical thumb installed on the backhoe. I'm wanting to convert the mechanical thumb to a hydraulic thumb and am wanting some help figuring out which hydraulic cylinder to get to convert to hydraulic. i just can't figure what hydraulic cylinder to start with. does that make more sense.
This is the cylinder I used to convert my BH77 thumb to hydraulic:
Chief WX Hydraulic Cylinders | Bore 2in. Bore - 3000 PSI 2 X 10 WLD CYL 1.125 ROD 207-384
This cylinder, with the BH77 and Kubota mechanical thumb, allows full retraction and more extension than the stock manual link. Without the 1/2" spacer (see below) the thumb hits the cylinder upon retraction and the rod lacks full retraction by about 5/8". With the spacer, the thumb retracts fully and stops its swing about 1/8" from hitting cylinder in its storage position. Upon full extension, the ram stops with the piston rod about 1/8" away from hitting the end of the dipper stick - so max extension and travel is had at both ends of the cylinder stroke.
An advantage of this cylinder is that you can change how the ports are oriented. But, like most cylinders you might purchase, this one too is just "almost" right. It can be used as is, and I did so for awhile. But to be absolutely perfect for the job, it needs to be 1/2" longer. I cut off the cylinder end fitting and welded it back in with a spacer. I tack welded this in place mounted to the hoe to correct for a slight misalignment that existed, probably in the hoe brackets (it amounted to a hair over 1/8" off set in the rod end so no big deal - - but if you're welding it anyway . . .
BTW, not necessary to take apart the cylinder to weld or cut - unless you want to. When I was welding the spacer I extended the rod all the way to get the seals away from the heat, then wrapped a wet rag around the cylinder near the weldment. No problems at all.
There are other threads on this endeavor with more info. Dfkrug is one of the pioneers and instrumental in getting a number of us off our butts and doing this mod which is seriously worthwhile!
the width you decide on is influenced by what you plan to use it for. If you are trying to hold looser
materials inside your bkt, then making the thumb nearly as wide as your bkt makes sense. If, however,
you are grabbing rocks, logs, or branches, a narrower width will reduce the twisting forces on the
thumb without adversely affecting the grabbing action.
To make things simplest, I went with a width that was the width of the dipper + 2x the width of the
steel sides of the thumb, plus some clearance.
/ Custom hydraulic backhoe thumb #188
Thanks, It seem this will be a piece meal project, will be working on it as time allows. Will post update
/ Custom hydraulic backhoe thumb #189
bumperm. thank you so much for the response. the cylinder looks real close to a kubota cylinder which i thought wouldn't be a big deal but seams like might as well get something that looks close. thanks for your reply.
rob
/ Custom hydraulic backhoe thumb #190
Aquamoose
The cylinder from Surpuls Center was to long. I mistook reracted length for overall length. My solution,since I don't weld, is to have a hydraulic shop shorten it 2 1/2". I found one from Bailey Hydraulics, but it too would have to be modified because the ports are on the top or bottom and they need to be on the side. It would be nice if Ansung could just stock a cylinder for those who want to convert to hydraulic. They make all the other cylinders already anyway.
I am getting another valve block from Walvoil that is the same as the stabilizer valve. I'll insert the new valve between the stabilizer valves with a longer handle and reassemble with longer bolts. There is enough room to do this and curl and thumb can both be active together. Probably be one to two weeks before I can assemble and post some pictures.
/ Custom hydraulic backhoe thumb #191
Thanks Ron50. I feel bad that you're going through this via trial & error while I'm sitting pretty, waiting.
I agree, Amsung should have a stock cylinder & parts to make an option. In time, I hope I can return the favor somehow. I'm working on a few projects which may be of interest to you.
/ Custom hydraulic backhoe thumb #192
My God, I have some catching up to do! I have not logged in a while. This thread is going like the Energizer bunny. You guys have been busy. FYI my Kubuta BH77 Hydro thumb (AKA Brian/DFK/BUMPERM) Hybrid was running strong right up until the hoe came off for winter so the tractor could go into snow service. Turns out we only had six inches of snow so far this winter. Last year, we had 104". Go figure.
/ Custom hydraulic backhoe thumb #194
Great thread, lots of information. When I get my new to me/ used BH65 hooked up I plan on upgrading the thumb to hydraulics.
/ Custom hydraulic backhoe thumb #195
The funniest thing just happened just as I was getting ready to quit working in my shop last night. (Actual work, I work from home, doing,...work stuff, but in a different part of my shop). I stepped out in the main area where my tractor & BH76 backhoe was at and I just took a looking at it, which is on a rolling storage dolly, and spied a yellow scrapped project cylinder next to it on a shelf. I looked at the BH thumb, then the cylinder. Pause. Thumb. Cylinder. Thumb, then cylinder.
"Naw" I declared while my brain said "Oh for pete's sake, check it out!"
Lacking confidence, I grabbed the cylinder and positioned it next to the mechanical thumb to see if it was the right length.
It was identical.
I then though that the pins wouldn't be the right size. Took the top pin out to try it on the cylinder holes.
It matched.
"Too good to be true, the thumb would bang against the cylinder" I thought. So I took the pins out, yanked that tubular thingamabob and placed the cylinder in the same spot.
It fits.
The hydraulic gods have shined upon me! I shouted with excitement while my poor lab looked at me as if I lost my marbles and waited by the door, wanting to go back in the house.
Of course, I'm momentarily cursed by the time constraints of my busy work schedule (blessed nevertheless) but I'm definitely am going to excited to jump on this very soon!
Thought I'd share it with you all before I hit the sack. Hopefully I'll sleep.
Woot!
/ Custom hydraulic backhoe thumb #196
Aquamoose,
What ho!! What are the chances of something like this coming together at one point in the time-space continuum? This is surely a powerful omen . . . stronger and more emphatic even than the burning bush was to Moses. Good grief man, get ON it!!
/ Custom hydraulic backhoe thumb #197
You don't need sleep, you need a hydraulic thumb.
/ Custom hydraulic backhoe thumb #198
Yeah, I know. I just got done for the day but I'm bone tired. I'm still stoked though!
I'm sitting here re-reading the past postings and I was focused on the Hydraforce valves and I'm sort-of confused as to how they work. I thought they simply worked as an on-off valve but I'm reading the specs that they also act as check valves so now my brain is a little mushy. bumperm, think you could help this fella out here? I'd love to get that same valve you have but with Weatherpak connectors. Once I can find the correct valve, I believe I can slap everything together as fast as I can shave a cat.
And yes BAP, I need a hydraulic thumb, with a ripper!
/ Custom hydraulic backhoe thumb #199
Scratch the connector preference part. I'm not going to be picky.
/ Custom hydraulic backhoe thumb #200
well I have finally started acquiring parts for a build on my CLB40, While looking for equipment for another project, I found a Gentec Hydraulic thumb at auction, lucked out, it was a steal!
now for the valve, after checking specs 10.65, I think I might be better with the Hydraforce SV10 VS SV8, any opinions?
Next questions has anyone done anything about pressure relief valves? I have to get time to read the entire post but I didn't remember seeing anything there.
All info is appreciated!
2023 Ram 1500 Crew Cab - Built to Serve Edition (A66408)
2023 Ram 1500 Crew...
2022 TEXAS PRIDE DUMP TRAILER (A65643)
2022 TEXAS PRIDE...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
2021 John Deere 4044M (A64126)
2021 John Deere...
New 43X16-20 NHS tire on 6-lug John Deere compact tractor rim, Coal Valley, IL (A65640)
New 43X16-20 NHS...
