Cub Cadet XT1 EPS
/ Cub Cadet XT1 EPS #1
GTSRider
Cub Cadet 3000
Hi , someone out there must have had my problem as these EPS systems are junk and fail. Here’s where I’m at … the unit was replaced under warranty at about 100 hrs , now at 200 hours the electronic side of it failed the replacement motor is fine when power was put to it . The new replacement is $1,000 not even a consideration. Can anyone come up with an idea to fix electronic side …. because no power is coming out of plug to power steering shaft …see pictures of electronic side and motor.
/ Cub Cadet XT1 EPS
Notice # 618-07167 has been superseded by 918-07167
/ Cub Cadet XT1 EPS
Ok … so part is still the same , not updated ?
/ Cub Cadet XT1 EPS #5
MTD just changed the prefixes when they re-cataloged. That change doesn't equal a part spec change. Have you tried their CAC for at least some goodwill assistance?
All that aside, I've not opened one up but have similar ish types of things. If push comes to shove, hopefully one can figure it out or reboot the thing w/ manual steering. Yuk.
Case IH 200 50' Field Cultivator (A66285)
Case IH 200 50'...
John Deere 2640 Tractor (A62613)
John Deere 2640...
2022 EZ-GO ELITE...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
2006 JOHN DEERE 700J LT CRAWLER DOZER (A65053)
2006 JOHN DEERE...
