Cub Cadet XT1 EPS
/ Cub Cadet XT1 EPS #1
GTSRider
Gold Member
Cub Cadet 3000
Hi , someone out there must have had my problem as these EPS systems are junk and fail. Here’s where I’m at … the unit was replaced under warranty at about 100 hrs , now at 200 hours the electronic side of it failed the replacement motor is fine when power was put to it . The new replacement is $1,000 not even a consideration. Can anyone come up with an idea to fix electronic side …. because no power is coming out of plug to power steering shaft …see pictures of electronic side and motor.
/ Cub Cadet XT1 EPS
Notice # 618-07167 has been superseded by 918-07167
/ Cub Cadet XT1 EPS
Ok … so part is still the same , not updated ?
/ Cub Cadet XT1 EPS #5
MTD just changed the prefixes when they re-cataloged. That change doesn't equal a part spec change. Have you tried their CAC for at least some goodwill assistance?
All that aside, I've not opened one up but have similar ish types of things. If push comes to shove, hopefully one can figure it out or reboot the thing w/ manual steering. Yuk.
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
1057 (A63291)
1057 (A63291)
2001 Wellcraft Boat w/ 2000 Boat Trailer, (A61574)
2001 Wellcraft...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2026 Electric Tricycle (A64194)
2026 Electric...
