CUB 3205
/ CUB 3205 #1
terry beavers
cub cadet 3205
Hi! I'm a new member looking for an answer to a front pto problem. My cub 3205 s vacuum actuator will not disengage. I checked the switch seems to be working. Could it be a bad selinoid not letting the actuator release? Thanks,Terry
/ CUB 3205
I'm going to replace the vacuum selenoid.
/ CUB 3205 #6
Is it serviceable? It might have a piece of debris stuck in it preventing it from operating. I have to service water solenoids all the time at work. Even thought we have to filters in front of the solenoid. Just a thought.
/ CUB 3205 #7
Had this problem early on with my 8 yr old 3204. The electrical operated vac valve was serviceable (at least on the one that came on mine) & I took it appart and cleaned it well. Don't recall if I put any lube on the moving part(s) but it hasn't caused me any problems since then. If I did put any lube on some parts it would have most likely been the silicone spray I have and used for yrs that drys leaving only a film.
/ CUB 3205
When I turn the pto switch off, the vacuum actuator releases some but not enough. When I disconnected the vacuum line it does release fully.When mowing the blades will decrease speed almost to a stop. I noticed it looks as if the actuator is not pulling shut all the way also.
/ CUB 3205
I cleaned the solenoid with no luck. I didn't use any type of lube though. I will reclean and lube this time.
/ CUB 3205 #11
I had similar problem. My solenoid was getting plugged with dirt on the vent side port. You could try spraying WD-40 through the solenoid both when engaged and not engaged to try to clear passages. IF that doesn't work. I suggest replacing solenoid. Also, you might want to test the vacuum actuator with a mity vac tool or similar. Disconnect hoses to actuator, connect mity van and pump it down. SHould begin to pull at 3-4" Hg and be fully retracted by 10" Hg. Should stay retracted and hold vacuum without bleeding down.
2010 RU SYSTEMS SMART 850 SIGN TRAILER (A66091)
2010 RU SYSTEMS...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
FIXED FIFTH WHEEL ATTACHMENT (A68842)
FIXED FIFTH WHEEL...
AG Tires - 11.00-16SL (A68134)
AG Tires -...
porta potty (A67714)
15-19.5 Tire and Wheel (A68134)
15-19.5 Tire and...
