CT235 fluid leak
/ CT235 fluid leak
Sorry for not updating, I did receive my endoscope but I was unable to find the source of the leak. I use my tractor to much in the summer time to warrant taking it apart. I am just going to add fluid as needed, at least thru the summer and fall. Come winter we will see how it goes. I am leery taking it apart not knowing for sure where the leak is. Numerous places it could be. 3 hard tubing lines tie into the pump, two flanges on the pump, at least 3 oil seals and I'm not sure just what else. I was unable to see very much of those places. Probably got the wrong endoscope. I do know it would be a major job. I'm pretty confident in the tear down and put back together but how sad I would be if I did all that and didn't fix the leak. Anyone with advice? I'm all ears! đź‘‚
/ CT235 fluid leak #12
I cannot help much, but I did have a hydro leak a few years ago on the cooling lines, apparently there is a design flaw that causes the lines to vibrate and eventually fail
Simple fix, is to replace them
/ CT235 fluid leak
Wouldn't be simple to replace the ones in that pump housing. I suppose that might help with assurance of no leak at those lines but that would sure get expensive. I hate being a parts changer. May have to be.
/ CT235 fluid leak #14
Yea, the coolant lines are long and a bit expensive, but easy to replace, and there are only 2 of them. I replaced the one that failed, need to replace the second one and fasten the mid hanger that I did not do on the one I replaced, I have to screw with the loader mount to finish it, and at the time I just needed to fix the leak, and like most of my projects I never got to finishing......
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
2001 Chevrolet Suburban SUV (A59231)
2001 Chevrolet...
Iranch IRGC40 High End Golf Cart (A60463)
Iranch IRGC40 High...
2016 FREIGHTLINER CASCADIA 125 6X4  T/A  SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2014 Freightliner Derrick Digger (A60352)
2014 Freightliner...
