Coolant overflow tank
/ Coolant overflow tank #1
Rmd8136
Ft mill, sc
Deere 5065e MFWD
Just got my 5065e yesterday and have 7 hrs on it. The coolant tank is above Cold about 1/2 inch when cold. It stays there when hot. I checked to radiator cap when cold and it is slammed full dripping off cap. It runs middle of Green on indicator 2 hrs into bush hogging (hot). Should the level be higher than slightly above Cold when cold.if I need to add coolant should I use JD coolant.
/ Coolant overflow tank #2
As long as the level is between cold and hot when cold, the level is fine. I would recommend using JD CoolGard II when you do add. CoolGard II is a 6 year/6000 hour coolant. If you add a different coolant, deere recommends changing at 2 years or 2000 hours. The CoolGard II was specially formulated to handle demands of Tier 4 emission engines.
2023 JCB 270T SKID STEER (A65053)
2023 JCB 270T SKID...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
Kewanee 12A Cultamulcher (A66408)
Kewanee 12A...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2015 Timpte 40' Hopper Bottom Trailer (A64127)
2015 Timpte 40'...
