Convert mule drawn to 3 point?
/ Convert mule drawn to 3 point? #1
JBGOATS
SC
'74 FORD 3000
Hello all. I have a mule drawn Cole planter, one row, that I would like to convert to three point hitch. The old planter is in very good condition and has a separate fertilizer hopper as well. I have found a few pictures of such a conversion, but could not actually tell how they were mated up to a cultivator frame. Have any of you ever attempted this? Thanks.....
/ Convert mule drawn to 3 point? #2
Hi. Welcome to TBN.
There are a lot of folks on here who can help.
/ Convert mule drawn to 3 point? #3
TBN has lots of mechanical geniuses, but without photos of the actual machine, someone will tell you to weld the framis to the doodad, when you should have welded it to the doohickey.
Bruce
/ Convert mule drawn to 3 point? #4
I used to attach a Cole one row mule drawn planter to the lift mechanism of a John Deere M with a bolt or two through the frame. It worked just fine. The M had no 3pt hitch. The images from a google search should give you lots of ideas.
one row planter - Google Search
/ Convert mule drawn to 3 point? #5
Some of the Google immages will show a plow foot ahead of the planter to open the furrow. I didn't have one of those. To open the furrows I used the middle busters that were a part of the mounted cultivaror setup on the tractor. They followed exactly in the center of the wheels. I took off all the other cultivator feet and used the middle busters to lay off all of my rows. I then straddled the furrow and planted my corn with the planter. This was one of the most satisfactory tractor attachments I ever had.
Thanks Bruce... I'll see if SWMBO will assist in getting some pic's.....
stuckmoter, that's what's kickin my mule.. I cannot find anything which shows how to mount it to a 3 pnt cultivator..
Jb - Up Low Country, SC
/ Convert mule drawn to 3 point? #7
JBGOATS.
From the Google and Yahoo image searches I've done, I suspect that the frames of the mule drawn and 3pt hitch planters varied slightly in addition to having different adapters according to what pulled them. Those searhes gave one or two photos of a planter mounted on a rear mounted cultivator. The places where they hook together are difficult to see though. I used the Cole planter in the late 60's to early 70's and never welded any of my mods. They were cobbled togather from odds and ends part being wooden. The planter belonged to my grandfather and he wanted it left original so he could pull it behind his tractor with a chain and hired man. He'd sold his mule at the time. I still miss that mule.
/ Convert mule drawn to 3 point? #8
I have a factory made Cole one row 3pt planter. I havent used it in a few years. Not looking straight at it right now, but memory tells me it is just bolted to the top of the cultivators. You adjust the cultipacker wheels by adjusting the top link. The layoff plow on the front of the planter is adjustable. Set the cultipacker right and then adjust the layoff plow for right depth and start planting. While mine also has the fertilizer box, I never put fertilizer in it, saves on cleanup not having to wash out fert residue and puts a stop to rusting issues as well. I also remove the cultivator feet since I till the soil before planting. I also broadcast the fert before tilling.
Okay, I am at a lost. Took some pic's, and she helped me down load them from the camera, but I'm having trouble trying to forward the pictures of the planter to TBN..... Any suggestions? Thanx.... Jb
/ Convert mule drawn to 3 point? #12
Use Paint first to reduce the size of the pictures (using its resize option right at the top just left of center) to around 500 pixels or so wide. Otherwise, they'll be way to big for us to view them from an overall perspective.
Then use Tractorbynet's "Go Advanced" button to get to the photo upload option.
I converted an old implement for a JD M to 3 pt hitch, but I have no idea what this thing is that you're referring to, but I'll bet you can use something similar.
Ralph
/ Convert mule drawn to 3 point? #13
I wouldn't change anything on the planter. Don't change history. :)
For use on a 3 point, here is what I would do first. If it didn't work, I would make a light 3-point frame that would bolt to the planter.
Bolt one of these under the planter frame about where the front of the handles attach.
Attach the front tow point of the planter to your fixed drawbar with a connection that allows vertical swinging pivot motion so it can lift and pull. Don't use the top link at all.
Bruce
Coleman Back Home Screen House (A62613)
Coleman Back Home...
2018 Mahindra Mpact XTV1000S (A64127)
2018 Mahindra...
3pt Bale Spear (A64127)
3pt Bale Spear...
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
JOHN DEERE 606C - 6R30" CORN HEAD (A64277)
JOHN DEERE 606C -...
