Conduit wiring method
/ Conduit wiring method #1
DaveNay
Platinum Member
Waterman, DeKalb County, Illinois
John Deere 855 MFWD; Oliver 1850 Gas
I am adding a small (240V/30A) subpanel to a building adjacent to my workshop. A short length of the feeder will be underground through 1 1/2" PVC. Inside the buildings, I would like to stick with stapling the cable to the studs (for simplicity/cost/time). My question is, how do I make the transition from conduit to plane cable? Does the pipe just end with the wires coming out? Should I put some sort of a junction box with cable clamp (even though I would just run the cable straight through the box) ? I plan on using #8/3 UF cable.
Thanks,
Dave
/ Conduit wiring method #2
I am not sure how code would treat running straight out of the conduit although I would not see an issue other then mice etc., getting in it to trim their teeth on your wire. I typically pipe right to the panel but in your case, you could always get a small junction box (6X6) with concentric knock outs that go up to 1 1/2" or larger and use a male adapter/lock ring to tie to the box. Problem is, you now need to ground that box so you would be forced to cut the #8 UF w/ground and ground the box. My preference would be to simply run it out of the PVC conduit ensuring no sharp edges are there to cut the very tough UF jacket. Perhaps the inspector has a thought on making this transition.
/ Conduit wiring method #3
I'd just put a regular thimble (cap with a hole in it) at the end of the conduit and keep the cables intact all the way to the box. The thimble protects the cable from any sharp edges on the conduit.
(My monitor must be teetering on the edge, as I cannot make out the diagram you provided. Many pics show up dark, and the 'bright' adjustment is at its limit)
I modified the image for you. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Just putting a protective cap (thimble?) on the end of the conduit, or just a good deburring would definitely be my prefered method.
Dave
/ Conduit wiring method #5
Thanks for the image. What you show is what I did when I ran electric lines to my shed. If I remember correctly, I only used the conduit sweeps at each end to hold the underground cable burried in the trench. I add a wad of silicone seal also to plug the space and hold the wires centered in the conduit. Probably not necessary. As long as the wires are not connected outside a box, it should be okay.
/ Conduit wiring method #6
put a pvc straight (or 90 degree) lb box on the end of the conduit, glue a female threaded adaptor into the other end of the lb, and get a 1 1/2" cord grip of the correct size for the cable.
/ Conduit wiring method #7
I believe the controlling factor is the susceptability to physical damage (relative to the exposed wire). For example exposed wire could not be within 6' of the ground level in case of being hit by something. On a parking garage project, we were required to run rigid steel conduit to above 6' then could transition to PVC. (a car wouldn't be hitting it above 6')
Also notice that residential service wire fed from above is usually exposed, but fed from underground is in conduit.
The other controlling factor is that the insulation is rated for an exposed area.
The transition of conduit to exposed is fairly common. You don't need any special transition. If the edge of the conduit can cut through the insulation than the installation is poor.
Look at an underground feeder coming down from a utility pole. The wire is run down the pole and covered with a metal molding, then the wire runs into the conduit sweep. The conduit is then gooped up around the wire.
Local code guy will have the info.
A follow-up question.
I stopped by Home Depot last night to check on the cable, and both #8/3 NM-B and UF-B are the same exact price ($1.29/ft). Since I am planning to put this in conduit where underground, is the NM-B cable allowed to be exposed when inside the buildings? The NM-B would be much easier to work with than the flat UF-B, and also allow me to use a smaller conduit size.
Also.... why is the UF cable flat??? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
Dave
/ Conduit wiring method #9
NM cable is not permitted to be used in conduit running underground. Whatever cable/conductor you use needs to be approved for a wet location.
/ Conduit wiring method #10
We are not allowed to have romex or UF exposed. Your code may vary. UF is a pain to work with. I've only seen UF (underground feeder) come flat.
/ Conduit wiring method #11
I suppose the reason for this must have as much to do with a ground wire that is not covered. The other conductors in NM are THHN, approved for wet locations. The other possibility would be the NM vinyl covering influencing the decision to keep NM out of the conduit in wet locations. Frankly if this were me, I'd be pulling individual wires and piping it right to the sub panel after reducing the 1.5" PVC to 3/4" EMT via a J-Box
</font><font color="blueclass=small">( Frankly if this were me, I'd be pulling individual wires and piping it right to the sub panel after reducing the 1.5" PVC to 3/4" EMT via a J-Box )</font>
This is an option I am also looking at. Even though EMT is astronomical in price ($5/10ft stick /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif, remember when it was 74 cents??), it should still be less than the price of UF, even when the price of the wire is taken into account. Labor is not an issue, I will be doing it myself. I should be able to do this with THHN/THWN, right? Most of the runs will be straight pipe, so very little bending involved.
Edit....this posts sort of makes it sound like I am looking for the cheapest method, I'm not. But I am perfectly willing to take advantage of a less expensive option, and still do it right. /forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif
Dave
/ Conduit wiring method #13
I recently purchased a several lengths of 1" EMT. You are right, unbelieveable how much it went up. I think I was paying about $10 per piece from Home Depot. It has another meaning to me now to be sure and make sure my bends and cuts are accurate.
/ Conduit wiring method #16
RaT,
My code book says THHN is listed for dry and damp locations only. However, THHN/THWN is ok for a wet location. What is Type NM made with? I am still looking. The NEC® says Type NM may not be used where "subject to excessive moisture or dampness"
</font><font color="blue" class="small">( True enough, it just looks like crap. /forums/images/graemlins/grin.gif )</font>
This is a machice shed and barn.....there is enough crap looking stuff, this won't make a difference.
Dave
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A61572)
2025 HT360W Mini...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
2013 CATERPILLAR 305E CR EXCAVATOR (A64279)
2013 CATERPILLAR...
