Clear a logjam
/ Clear a logjam #1
Aggie66
Rockdale TX
MX 5400
We have a creek that runs through our property. To access the backside we had to build a bridge about 30 foot long to get across. Recent rains have caused a log jam at the bridge support pilings. Has anyone built an attachment that either will go on your bucket or if you’ve taken the bucket off and built some thing to fit where the bucket would attach to the front loader. I’ve used a winch to pull out some of the debris but I’m thinking that there may be a method to use the front loader with some sort of rake attachment to pull that debris out discussion and pictures would be appreciated. I have a Kabota MX 5400. thank you
/ Clear a logjam #2
The short forks:
The long piece of square tubing that attaches to the forks:
This is one thing that I used it for:
/ Clear a logjam
Thanks for the reply. This is a novel approach to use on the forks.
/ Clear a logjam #4
Forks are a good idea, I would be very careful if extending a boom off the FEL and trying to lift with it.
/ Clear a logjam #5
/ Clear a logjam #7
Lost one bridge in last weeks storm, and another one was moved off its foundation which I managed to move back....... Clean up was boots and chain.... There was no real way to get tractor close enough to problem to clear it, just plain old back breaking work and aid from portable ATV winch to get out to where I couild use chains and tractor... ......
/ Clear a logjam #8
I've had reasonable success with a set of log tongs hanging from a chain on the loader bucket or on the mini ex. Usually if you pull a few key pieces from a logjam, the rest will break loose and flow downstream. Just be careful, or you may be going downstream as well......Dan.
/ Clear a logjam #10
We built, what we call a beaver rake, to clean out the creeks or ponds
with. Can be mounted on the end of forks, 5' extensions, 10' extensions, or both is 15' extensions. Will reach over 20' from front wheels.
/ Clear a logjam
You’re going to want a pike pole, whether you have a loader attachment or not.
Could you explain a pike pole. I’m not familiar with that. Thanks photo or web reference would be helpful
/ Clear a logjam #13
The safest method is to connect a choker to the outside or upper log and pull it out by attaching to your drawbar. Repeat until the jam is gone.
/ Clear a logjam #14
Thinking outside the box here...Can you burn them? Use a propane torch/weed dragon to ignite them (NO ACCELERANTS!)? The fire will weaken/collapse the jam.
/ Clear a logjam #15
I built a larger version of this to remove a beaver dam one time, toss it over the dam, hook the winch to it and winch it in, repeat. The one I built was about 36" across, made with 1" pipe
/ Clear a logjam #16
I think it might be hard to burn a log jam in a flooded creek but after the waters recede maybe. might be hard to keep it from burning the bridge at the same time.
a mini ex with a thumb would be just the ticket. we all need excuses for more toys.
/ Clear a logjam #17
Use a digger with a thumb. The size of the logs will dictate the digger size. What weight is the bridge rated for? Maybe hire a "Long Reach" (16 metre) digger.
/ Clear a logjam #18
Even the big guys just use what they have on hand.
Bruce
/ Clear a logjam #19
Why not just cut the logs? Smaller logs float away easier. If you want to keep them on the property cut them and burn them.
/ Clear a logjam #20
Rent a Mini-X with a grapple and rotator for handling logs. Thumb only works well when logs are perpendicular to the boom.
New/Unused SD Lanch EDLL Mini Skid Steer (A61166)
New/Unused SD...
12ft Cattle Panels (A64047)
12ft Cattle Panels...
2019 International DuraStar 4300 Service Truck, VIN # 1HTMMMMN1KH714519 (A61165)
2019 International...
2020 CATERPILLAR 299D3 XE SKID STEER (A62129)
2020 CATERPILLAR...
New/Unused Landhonor Leaf Blower (A61166)
New/Unused...
(INOP) KUBOTA ZG327 ZERO TURN LAWN MOWER (A62130)
(INOP) KUBOTA...
