CK25 Transmission Grinds
/ CK25 Transmission Grinds #1
blue262
Louisiana
2006 Kioti CK25
I recently purchased my first tractor, a CK25. It is a shuttle shift I beleive. I understood this to mean I must come to a stop before shifting between forward and reverse. I find it still makes a grinding noise sometimes, even if I let the rpm's come down to idle. It doesn't do it all the time and I have adjusted the free play in the clutch linkage to specs. Has anyone else had this problem or can you give me advice as to what I'm doing wrong?
/ CK25 Transmission Grinds #2
Is it new or used?
How many hrs etc
BTI
399 hours after today.
/ CK25 Transmission Grinds #4
mine "dk40" does it sometimes, mostly if i pull the handle to fast to the oposite position. if i just pull it from say forwards to reverse but i pull it slow and smooth through nutral it wont grind.
/ CK25 Transmission Grinds #5
Ditto on my CK25. Also, if I don't firmly pull/push it into reverse/forward. Keeping the linkages lubed helps with this.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2025 Swict 72in Bucket Skid Steer Attachment (A59228)
2025 Swict 72in...
2018 PJ Trailers 14ft T/A End Dump Trailer (A59230)
2018 PJ Trailers...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2019 INTERNATIONAL...
12' CONTAINER (A52706)
(32) 8" FLOOR TRUSSES (A60432)
(32) 8" FLOOR...
