CK25 Transmission Grinds
   / CK25 Transmission Grinds #1
blue262
Louisiana
2006 Kioti CK25
I recently purchased my first tractor, a CK25. It is a shuttle shift I beleive. I understood this to mean I must come to a stop before shifting between forward and reverse. I find it still makes a grinding noise sometimes, even if I let the rpm's come down to idle. It doesn't do it all the time and I have adjusted the free play in the clutch linkage to specs. Has anyone else had this problem or can you give me advice as to what I'm doing wrong?
   / CK25 Transmission Grinds #2
Is it new or used?
How many hrs etc
BTI
399 hours after today.
   / CK25 Transmission Grinds #4
mine "dk40" does it sometimes, mostly if i pull the handle to fast to the oposite position. if i just pull it from say forwards to reverse but i pull it slow and smooth through nutral it wont grind.
   / CK25 Transmission Grinds #5
Ditto on my CK25. Also, if I don't firmly pull/push it into reverse/forward. Keeping the linkages lubed helps with this.
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A52748)
2023 NEW HOLLAND...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
2019 D&P WELDING  12FT LUBE TRAILER (A52472)
2019 D&P WELDING...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
