CK25 Transmission Grinds
/ CK25 Transmission Grinds #1
blue262
Member
Louisiana
2006 Kioti CK25
I recently purchased my first tractor, a CK25. It is a shuttle shift I beleive. I understood this to mean I must come to a stop before shifting between forward and reverse. I find it still makes a grinding noise sometimes, even if I let the rpm's come down to idle. It doesn't do it all the time and I have adjusted the free play in the clutch linkage to specs. Has anyone else had this problem or can you give me advice as to what I'm doing wrong?
/ CK25 Transmission Grinds #2
Is it new or used?
How many hrs etc
BTI
399 hours after today.
/ CK25 Transmission Grinds #4
mine "dk40" does it sometimes, mostly if i pull the handle to fast to the oposite position. if i just pull it from say forwards to reverse but i pull it slow and smooth through nutral it wont grind.
/ CK25 Transmission Grinds #5
Ditto on my CK25. Also, if I don't firmly pull/push it into reverse/forward. Keeping the linkages lubed helps with this.
2015 Ford Transit Connect Cargo Van (A61573)
2015 Ford Transit...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
Volvo EC220EL (A60462)
Caterpillar 980F Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 980F...
2017 Ford F-250 4x4 Crew Cab Medical Service Truck (A61573)
2017 Ford F-250...
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
