CK series engine HP differences - tuning only
/ CK series engine HP differences - tuning only #21
The snowblower has a maximum volume of snow it will move at pto speed and I was at that limit. More hp would only burn more fuel.
Still curious how to increase the hp...if I need it.
Not necessarily your tractor should only use the amount of fuel it needs for a specific task upping the max amount of fuel the pump can deliver (upping the max HP) will not change the fuel used if your not pushing it more. Say you are blowing 5 ton of snow per hr your tractor is going to use a given amount of fuel to do that work and use the hp needed. If you up the max fuel delivery to increase your hp and still blow 5 ton of snow per hr your fuel use will still be the same because you are still doing the same amount of work.
/ CK series engine HP differences - tuning only #22
We're talking about tier 3 engine, no computer. A dash mounted knob or switch would be nice to vary power.
I may be wrong, I'm not a diesel mechanic. If you change the injector timing ( make it stay open longer during an intake stroke ) you would be putting more fuel into the cylinder. Thus using more fuel. You still have to operate at pto speed for the given task.
/ CK series engine HP differences - tuning only #23
Thanks for that information Coyote, That goes along with my original thought - it takes specialized equipment and tinkering to achieve "whatever" max output from an engine. Far, far beyond me. I was just curious as they all seem to be the exact same engine otherwise. I'm happy with mine as is, and believe like you - "If I wanted more power I should have bought a bigger tractor."
Thanks, Greg
Problem is that if you want a "bigger" tractor and consider more HP to be "bigger" then you are playing into Kioti's (and other manufacturers) marketing scams. The entire Kioti NX line from 45hp to 60hp has exactly the same engine with different software programming. The loader, hydraulic pumps, 3PT and total tractor weight are also essentially identical. I think the 60 has slightly taller rear wheels. No biggie except that the marketers charge almost a couple thousand bucks for each 5hp increment in "software" programming. If you like the idea of being scammed then get the 60hp version as a great (not) deal. If you don't like being scammed get the 45.
/ CK series engine HP differences - tuning only #24
If parts manuals are available, compare the part numbers for the pistons, block, piston rings, injectors, bearings, oiling system etc between the various hp models. That will tell you if there are any real differences besides the injector pump settings.
Maybe a call to an injection pump shop could reveal the truth, ask them "If my Kioti 45 hp tractor injector pump was trashed and I found a 25 hp injector pump at a bone yard, could you adjust it to give me 45 hp?", "Would you have to order any parts to do it?". You could always give them $5 for their time.
/ CK series engine HP differences - tuning only #25
I wouldn't be surprised that one of the strategies behind the detuned offerings is that a lower hp variant of the exact same engine has statistically fewer warranty claims. This would allow them to offer the same engine but with lower hp at a lower price while maintaining the same profit margin or better.
/ CK series engine HP differences - tuning only #26
These engines are so reliable that I doubt they would ever need to change the price to cover warranty costs. I think it is a plain old marketing game. Americans love horsepower and are willing to pay more for it. Offer to boost the horsepower and charge them more for it. Some VP of Marketing got a nice bonus check for figuring out that strategy.
/ CK series engine HP differences - tuning only #27
I don't disagree with your position, however the CUT market is pretty competitive, and I don't think market pressures allow for just a simple increase in price where there is no relative increase in cost. Consider how expensive a warranty claim is for the company; they have to pay those labour costs out directly to the independent dealers. A single warranty claim, can easily cost them their entire net profit margin on a tractor.
Even if it isn't calculated that way, you might also find, that they only amortize the development cost for both variants on the more expensive one, or they might have a combined profit margin target for the two together.
There are only a few companies in North America that can get away with just simply charging more, and don't think you'll find any of them are Asian-based.
/ CK series engine HP differences - tuning only #28
Kioti, JD, Kubota all do this. They started doing it once engines became turbocharged and electronically controlled. Yanmar also does it with marine diesels and I'm pretty sure Cummins does too. All of these engines are excellent and would be expected to easily outlive their warranty periods. I wouldn't disagree that the identical engine tuned for 35hp would statistically last longer than one tuned up to 45hp but the overwhelming odds are that both variants would easily go 3000+ hours so would be long out of warranty by the time any failure occurred.
And, note in the discussions here that 1) engine failures are rare as hen's teeth and 2) almost nobody has engine longevity as their major criteria in selecting one brand or one model over another. These modern engines are just diesel powered versions of the Energizer Bunny. The other point is that marketing guys are pretty smart and know full well that people will pay more for more horsepower even if they rarely use it and even if there is fundamentally no difference between different engine versions. I haven't priced them recently but I believe Kioti is getting a premium of something close to $1000 for every 5hp increase in rated output. And, they are clever enough to offer 45, 50, 55 and 60 hp versions of the NX so even if you decide not to splurge on the 60, they still might wring a few extra bucks out of your wallet if you settle for the 55 or 50.
/ CK series engine HP differences - tuning only #29
I understand what you're saying, I'm just pointing out that there's a lot more factors to consider than just dismissing it as a marketing cash-grab. As much as it might be a way to sell unneeded hp at a premium, it may also be a means to provide a more affordable alternative to those buyers where that extra couple thousand dollars is a roadblock.
Consider Kubota. Based on their reported revenues, they earn an average net profit of 8.7% on the wholesale price of each tractor they sell. If you look at three identical tractors electronically tuned to different hp, the input costs are the same, but the profit margins are different e.g.: wholesale prices of 25,000, 26,000, and 27,000 would have net margins of 1,262, 2,262, and 3,262 respectively. That's not a lot of margin to play with. At 8.7% net income on a company that size, any minor strategic error is the difference between profitability and loss. If some one were to find a hack and release it to the public where everyone stopped buying the higher tuned versions, it would be financially devastating to the company.
In the end, yes, it is all about profit. But I don't think it is an insidious as you suggest. If tractor companies could not build tractors for a profit, they would simply cease to make tractors.
/ CK series engine HP differences - tuning only #30
We don't actually disagree. I guess my point to potential buyers is that they should consider their horsepower requirements very carefully. There are precious few things that the NX6010 can do that the NX4510 can't also do efficiently. I've always felt that the lowest horsepower tractor in a given frame size is generally the best bang for the buck. If you want to spend more money then go up a frame size. A Kioti RX6010 will kick sand into the NX6010's face and they are pretty close in price.
/ CK series engine HP differences - tuning only #31
I agree. I'm a true believer of evaluating what I need versus what I want. That way I can determine what my ego costs. :laughing:
In my case, I bought a tractor bigger than I initially sought. I was originally looking at a new 25hp, but then after evaluating the specs compared to the projects I had lined up, I realized the the 25hp was not going to do the trick. Then a used 41hp popped up for sale with low hours and low price, and came in much cheaper than the new 25hp would have been.
For me a 60hp would be overkill. Even if I could electronically increase the hp I probably wouldn't unless it had a real benefit to me, which at this point in time I can't even anticipate.
/ CK series engine HP differences - tuning only #32
Tractor pricing should be broken down into "the needful" and "the big boy toy" elements. Of course it must never be seen by wives but we should at least be able to use such data to stare our egos down at moments of weakness.
/ CK series engine HP differences - tuning only #33
I went from a 27HP Cub cadet to my NX4510 45HP tractor. This was an incredible upgrade in size and HP. I bought it brand new as a leftover for $21,500 with the loader and a 6 year warranty. It was well after the fact that I started to do some real research and noticed that the 45, 50, 55 and 60HP motors were all the same size engines. That is when I started to ask questions to see if anyone had found a way to push out 60HP out of their smaller HP tractors. All four tractors are identical except for the HP of the motors. When I get some more time I will start revieing parts for the 45 and 60 to see exactly what parts are different as in the camshaft, injection rail, etc.
/ CK series engine HP differences - tuning only #34
I went from a 20 hp Farmall C to the 27 hp Kioti. The main thing I was looking at was the overall size of the tractor for the areas I need to clean in winter. I can get into some pretty tight spots with the Kioti that I couldn't with the Farmall.
I was also sick and tired of getting stuck with the Farmall and wanted a 4 wd tractor and cab. In four and a half years with the Kioti I've only needed a tow truck once and that was at the start of last winter.
2006 GMC C6500 Crew Cab Chipper Truck (A61568)
2006 GMC C6500...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
2020 CATERPILLAR 305.5E2CR EXCAVATOR (A62129)
2020 CATERPILLAR...
2018 Dodge 5500 Bucket Truck 4WD (A63118)
2018 Dodge 5500...
2025 SDLANCH SDLC2020 High End Carport (A60352)
2025 SDLANCH...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
