check valves for top link
/ check valves for top link #1
kully
upper ny,and long island
kubota m4900 with loader
looking to build a hydraulic top link but cannot find double pilot check like the ones used in the ccm top link. can I use a regular inline check valve for hydraulic flow one way. I need a certain length so I need to get a 3x8 cylinder and check valve it . will it work the same and not drift ,I was thinking should I use 2 inline check valves or just 1 thanks
/ check valves for top link #2
I have seen a double piloted check valve offered at eBay on more than one occasion, that's where I would start. Grainger's also offers them new.
/ check valves for top link #3
</font><font color="blue" class="small">( I have seen a double piloted check valve offered at eBay on more than one occasion, that's where I would start. Grainger's also offers them new. )</font>
Just be careful that you understand how these double pilot operated check valves work and factor that into how you will be using the cylinder. Depending on the application the readily available ones may work just fine. For a top link they won't. Here is a link to the post that talks about the double pilot specs. It starts about half way thru the discussion.
double pilot operated check valve spec discussion
/ check valves for top link #5
</font><font color="blue" class="small">( looking to build a hydraulic top link but cannot find double pilot check like the ones used in the ccm top link. can I use a regular inline check valve for hydraulic flow one way. I need a certain length so I need to get a 3x8 cylinder and check valve it . will it work the same and not drift ,I was thinking should I use 2 inline check valves or just 1 thanks )</font>
Try contacting someone at a "Parker Hannafin Hydraulics" outlet. Most major cities have them (One in Louisville I know) They should have what you need.
Talk about timing!!!! I just "installed" my FIRST CHOICE hydraulic top link today, on my finish grading tractor. I bought it through Sweet Farm Equipment.
Here's a picture!
/ check valves for top link #6
And another view!
Nothing like a new toy!
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A65054)
2016 INTERNATIONAL...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
10in Bucket w/ Teeth Excavator Attachment (A64194)
10in Bucket w/...
2021 KOBOTA SVL97-2 SKID STEER (A65053)
2021 KOBOTA...
2022 EZ-GO ELITE...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
