Charging battery
/ Charging battery #1
duck76073
kioti
Battery will not charge on vehicle. Removed battery and put on bench charges ok. Charging on vehicle the negative post gets extremely hot and discharge the battery. Help
/ Charging battery #4
If the post gets hot, it is probably a dirty connection on the post.
/ Charging battery #5
Probably your negative ground, but I'd check the ignition switch, too.
My 2025R had a small electrical leak in the starter relay that cooked the ignition switch and caused corrosion on both battery terminals.
/ Charging battery
Thanks a lot for all the comments
/ Charging battery
The battery is on my Chevy pickup. The charger negative terminal is what gets hot and shows to be discharging after 30 minutes.
/ Charging battery #8
Voltmeter? Battery should be 12.5 0r so and should be 13+ when runnimg. Leave your battery un hooked for a while and see if it holds a charge. 12.87 is what my meter reads on a good battery. It should be the same, hours later.
Don't disconnect battery while engine is running on the newer vehicles. That's a no no. Old ones it's okay to do that, new ones not. By old ones I mean before fuel injection.
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2014 KENWORTH T800 MIXER TRUCK (A63569)
2014 KENWORTH T800...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A63118)
Midwestern...
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2001 John Deere 6210 Tractor w/640 Loader LEFT HAND REVERSER (A64047)
2001 John Deere...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
