12V battery jump box recomendations?
/ 12V battery jump box recomendations? #21
only comment i will make if you live somewhere hot or don't use it much, don't charge it over 80%, the batteries don't like sitting at 100% for long periods of time without cycling, and most of these jump units, can jump multiple times before being dead
/ 12V battery jump box recomendations? #22
I have the Clore ES3000 and the ES6000, that I bought in 2006. The ES6000 was for my Dodge Cummins, which I sold. The ES3000 is in my Silverado.
One time years ago I had a dead short in my Dodge in the winter. Both batteries completely dead. The ES6000 started it easily.
/ 12V battery jump box recomendations? #23
My Noco drops off considerably after that battery indicator drops off one bar. Having the tool work is more valuable to me than preserving the optimal lifespan out of it.
/ 12V battery jump box recomendations? #24
The robust integrated captive leads and good clamps are great features.
I have the similar GB155.
Any of them with detachable leads would be an immediate no go for me. I know I’d end up loosing the leads plus it’s got to loose amperage at the connection.
/ 12V battery jump box recomendations? #25
These boxes have more use than just a jump box. On my GooLoo, the plug and socket seem well-made. I would not want the large alligator clips from dangling while the power is on and not connected to a battery. The clips are also well-made with plastic jackets to minimize them accidentally hitting each other.
If you never use your box as a power supply or source of light, then permanently-attached jumper cables make more sense.
/ 12V battery jump box recomendations? #26
My Noco leads attach securely to the side of the box so they aren’t swinging around arcing out. Plus even if they did hit each other nothing is going to happen because they aren’t live until the box detects power from a battery. I’ve used the box occasionally to charge my phone but I don’t make a habit of doing that and I have better flashlights.
/ 12V battery jump box recomendations? #27
It is amazing how small and capable the newer jump boxes have become. Some use lithium-ion batteries and some use large capacitors.
I have never had the larger boxes that have attached jumper cables on the sides. Earlier models like that were large, heavy, and used lead-acid batteries. All of the makers mentioned in this thread offer smaller units with detachable cables, and much larger units with fixed cables.
/ 12V battery jump box recomendations? #28
The NOCO Boost-X GBX155 unit rated #1 in the Project Farms head-to-head durability review.
4250A, great for jumping big diesel engines too.
I was surprised at the tests they did.
Worth while to watch and draw your conclusions if 2nd, 3rd or 4th place contenders would meet your needs.
I’ve started a completely dead 5.9 Cummins with the biggest 4250 Noco. Not only did it start it cranked over like the properly charged starting batteries do. I have the smaller 2000 amp Noco. I borrowed a machine with a 4bt Cummins that had a draw and killed the battery. I started it several times with the 2000 amp Noco.
/ 12V battery jump box recomendations? #29
it shouldn't, one bar should be 75%, i routinely run around there with mine, but its not a noco
I almost just made a jumper from scratch. I would have used a high CCA battery, then simply wired in 2 or 0-gauge jumper cables & stored it plugged into a smart charger. Weight wouldn't bother me, I'd have to have it in a substantial box with handle.
The battery was weak on my Deere 3038 so I went back to Wal-Mart getting an Everstart group 51R battery for $79. Only 1 year warranty but it started it fine.
/ 12V battery jump box recomendations? #31
a lipo models weighs less than a pound , will last longer, and take less room
/ 12V battery jump box recomendations? #32
Im not sure otherwise, but the thing about the NOCO is that at full charge it provides a "HARD" source to your system at a ~15 V level. This zaps your dead battery and the starter. It really spins the engine up for a few seconds. It will start if its gonna. -- At one bar down its more like jumping from a regular 12 battery .. and there also, only for a few seconds. The "Hot" 15V jump is a huge advantage, especially when the engine is cold.
/ 12V battery jump box recomendations? #33
is this some kind of mode? i have an idea of how these work, and those voltages don't make a ton of sense to me
/ 12V battery jump box recomendations? #34
More like a feature of the NOCO. The battery pack has a slightly higher rest voltage than a normal 12V automotive system, and can deliver very high current for a short time before dropping off to normal ~ 11V levels seen during cranking.
/ 12V battery jump box recomendations? #35
Do you suppose that is what the "boost" button on my GooLoo does?
/ 12V battery jump box recomendations? #36
I dont know. Typically you just get whatever voltage is present (characteristic of the type of cells and their current state of charge) and have no option to increase or decrease it with a button.
/ 12V battery jump box recomendations? #37
boost button typical is used when the voltage is so low on the battery the jump pack doesn't detect it. you will see it turn on and the relay click even if disconnected
/ 12V battery jump box recomendations? #38
I am also a fan of the Project Farm comparo on Utube. Very interesting the 2 types of boosters: battery-based and capacitor-based, and how they perform.
/ 12V battery jump box recomendations? #39
And the "winner" is???
SR
