Charging a battery
   / Charging a battery #1
DrRod
Platinum Member
Ellicott City, MD - Farm in Orbisonia PA (south ce
John Deere 4110
I'm sure I should know this but alas I just don't.
I have a Sears battery charger that surprisingly had no instructions in the box. So I am hoping the good people of this site can answer a few questions.
1. It has a 2 amp and 10 amp setting. Why would I want to use the lower setting? Does a slow charge make for a more complete charge?
2. It has two settings: Conventional Low Maintenance and Maintenance Free Deep Cycle. I normally use it to charge ATV batteries and they are sealed and labeled "Nonspillable." So I don't know whether I have a Conventional or a Maint Free battery and so I don't know which setting to use.
Greatly appreciate your thoughts on this.
Thanks,
Dr. Rod
   / Charging a battery #2
Quick, layman answer: use the 2amp setting for the maintenance-free ATV batteries. As far as I know, the "maintenance free" thing means you can't/don't-have-to add water. That's all. Small batts should be charged at the low setting. The longevity of small batteries is increased when they are initially charged at 1amp, not even 2amps.
I only use higher settings if I am forced to be in a hurry. Otherwise it is 2amps or less.
Maybe someone knowledgeable will let you know the reasons why....
   / Charging a battery #3
Quick answer to charging current... A high current relative to battery size is like a hot grill searing the outside of the steak. Only the surface gets charged. This leads to plate buckling and material drop out. Both bad news for batteries.
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
AGT Skidlaoder Post Hole Digger (A50774)
AGT Skidlaoder...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
Frontier AB13D Hay Spear (A50120)
Frontier AB13D Hay...
