Changing Solid Rubber Tire
/ Changing Solid Rubber Tire #1
pequeajim
Platinum Member
New Holland, PA
Power Trac 425
I have the new solid rubber tires on the front of my mower deck and (not a fault of the tire), I ran into something and the tire came off the rim.
I am looking for some advice to get it back on? I tried a crowbar, soap and water, but they go on the rim so tight that I need something to spread the tire so that I can push the rim back down in place.
Harbor freight has a couple of tire changers, but I think that they really only work with tubless tires, not the solid rubber like I have.
Any of you mechanical wiz's have an idea for me?
Thanks
Jim!
/ Changing Solid Rubber Tire #2
How about heating the tire in boiling water and then try mounting it.
sg
sg
I figured out a way to do it with some work. I mixed up some heavy soap and water and used a crow bar to spread the tire apart while I was stepping on the rim with my foot, pushing it down into the tire.
It took me about 15 minutes to do it, but the tire is back on!
/ Changing Solid Rubber Tire #4
O.K. Now take it off and photo-document the procedure for us. :D
Glad you got it back on. With it being so tuff to get on, don't you wonder how things like this come off in the first place? It remonds me of when I was a kid and use to take things apart and couldn't get them back together again. Heck, I still do that. ;)
/ Changing Solid Rubber Tire #5
I guess you wouldn't like my solution. I wrestled with the one on my brushcutter for over an hour and got so frustrated with it I took the sawsall to it and zip tied it back on. Ahh, good ole zip ties. :)
/ Changing Solid Rubber Tire #6
I did the same thing with mine, popped off when I hit an incline with the brush cutter at a bad angle. After about an hour of trying different ways of getting it back on the rim I accepted there was no way I was doing it. Took it to a JD dealer and $10 and 15 minutes later he came back out with it on. Oh yeah, there were a lot of bad words I heard coming from the back shop in those 15 minutes!
Jack
Boy... I came really close to doing that myself! The trusty crow bar and soap and water did the trick though.
/ Changing Solid Rubber Tire #8
My tire came off as well on the brush cutter. I spent about a half hour trying to put it on but it wouldn't go on all the way. So i took it down to a tire warehouse and 10 minutes later it was put on for us. they used a press and soap and water.
/ Changing Solid Rubber Tire #9
There is an old machine shop that I visit often in the town I work in. Many of the machines are still powered by overhead belts. One piece of equipment is a huge press that is hydraulic however the pump runs off one of the overhead belts.
On several occasions I have watched fork lift tires being changed, which are solid rubber tires pressed on the rims. Once the rim is positioned correctly over the tire many tons of force complete the assembly. The removal process takes almost the same amount of force.
I figure other solid tire wheeel assemblies are put together in much the same way. I have broken the bead on tires I wanted to change with a bottle jack a piece of 2X4 and the carrying beam of my house. I lay the tire on the floor under the carrying beam, place the bottle jack base on the tire next to the rim, and the 2X4 which is cut to the right length between the top of the bottle jack and the underside of the carrying beam.
A little jacking while kneeling on the opposite side of the tire and the bead usually slides off the rim. I would think a solid rubber tire and rim could be reassembled in much the same way. It would just take the proper positioning and holding of the rim or tire and a little push.
Randy
/ Changing Solid Rubber Tire #10
i HAD THE SAME THING HAPPE. fOR ME IT WAS DUE TO THE WHEEL DROPPING INTO A WATERING BASIN AROUND A SHRUB JUST AS i MADE A SHARP TURN. iT JUST WIPED THE TIRE OFF THE TIM.MH,
/ Changing Solid Rubber Tire #11
I had the same thing happen. For me it was when the wheel dropped into a watering basin around a shrub just as I made a sharp turn. It wiped the tire right off the rim.
I think the difficulty getting them back on is due to the fact that they are not really 'solid' tires. If they were the principle that what went on once should go on again would apply. Instead they are foam filled tires and I believe the foam is inserted after the tire is mounted so the inside diameter of the tire conforms to wheel hub diameter rather than wheel rim seat diameter.
After wasting an hour tying to get it on at home I took it to the neighbour's. He runs a tractor restoration service and has a very complete shop. We tried for 30+ minutes to get it on using a 30 ton hydraulic press. I ended up buying a new one but kept the old one, just in case. Perhaps this winter after the weather cools off and I don't have much to do I may give it another try just to pass the day.
/ Changing Solid Rubber Tire #12
When mine came off, I solved the problem immediately -- I mowed it. :D
The new ones are still on.
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
2019 JCB LSB72 Compact Track Loader Skid Steer (A61572)
2019 JCB LSB72...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
iDrive TDS-2010H...
2026 Kearney 7'x16' Trailer (A64119)
2026 Kearney...
