Changing Solid Rubber Tire
/ Changing Solid Rubber Tire #11
I had the same thing happen. For me it was when the wheel dropped into a watering basin around a shrub just as I made a sharp turn. It wiped the tire right off the rim.
I think the difficulty getting them back on is due to the fact that they are not really 'solid' tires. If they were the principle that what went on once should go on again would apply. Instead they are foam filled tires and I believe the foam is inserted after the tire is mounted so the inside diameter of the tire conforms to wheel hub diameter rather than wheel rim seat diameter.
After wasting an hour tying to get it on at home I took it to the neighbour's. He runs a tractor restoration service and has a very complete shop. We tried for 30+ minutes to get it on using a 30 ton hydraulic press. I ended up buying a new one but kept the old one, just in case. Perhaps this winter after the weather cools off and I don't have much to do I may give it another try just to pass the day.
/ Changing Solid Rubber Tire #12
When mine came off, I solved the problem immediately -- I mowed it. :D
The new ones are still on.
2019 Big Tex 10PI-20BK4HDIR 5 Ton 20ft T/A Flatbed Equipment Trailer (A59230)
2019 Big Tex...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A59823)
2017 KALMAR OTTAWA...
2019 John Deere R-4038 (A61307)
2019 John Deere...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
2004 JOHN DEERE 160C LC EXCAVATOR (A59823)
2004 JOHN DEERE...
