Oil & Fuel Change coolant every 2 years
   / Change coolant every 2 years #41
I really don't believe in justifying anything. Just out for Truth in pretty much everything.
But I am suspicious, and all too often when someone "suggests" something, they coincidentally gain from it. If the average person followed every maintenance proceedure for everything they owned, they would be overwhelmed.
   / Change coolant every 2 years #42
Sounds like everyone is having a different experience in this area or at least a different opinion. Emergency diesel pumps and gen sets are maintained in a manner almost like a fire truck should be. They need to start and run first try every time after standing for years without extended running times. Our worse case we would find anti freeze in the oil sump with oil testing indicating that the seal on a wet liner had failed or that a head gasket had failed. Spending a few bucks on a coolant change or maintenance was small stuff considering the cost of re-building a neighborhood or a half a million dollar engine. When you have a V16 Cat with a 10" bore, that ends up being a really big deal. Might be easier or better way to do that job,
Chris
   / Change coolant every 2 years #43
Two things,,
1) has anyone mentioned that "regular" car coolant can not be used in a diesel? "car" coolant can destroy the cylinders,,
2) research Rotella ELC coolant for your diesel, or other engine,, ELC stands for extended life coolant,,
I think the Rotella pretty much is a permanent coolant,,,
Rotella ELC is as cheap as anything at Tractor Supply.
   / Change coolant every 2 years #44
Two things,,
Good point. As well, some of the newer extended life coolants can cause problems in older vehicles. I forget why but I had to use regular old fashioned 2 year anti freeze in my 1967 Ford F600 truck. The modern stuff may have attacked solder in radiator joints or maybe it was the head gasket. Not sure but I resolved no modern A/F was going in that engine.
   / Change coolant every 2 years #45
Two things,,
If your tractor has a copper/brass radiator, (like in older tractors and cars) you might want to use caution with any extended life coolant. The pH on those is lower than traditional coolant, and can cause corrosion. If your tractor is newer, and has an aluminum radiator, it shouldn't cause any issues.
That was why I went with fleetcharge which is a traditional heavy duty coolant with SCA, rather than finalcharge, which is an extended life heavy duty coolant. There are plenty of good choices, I kind of went down a rabbit hole when I was looking.
   / Change coolant every 2 years #46
A couple years ago I switched to Fleet Charge in my old Ford 850 gas and Final Charge in my modern diesels.
My 850 had cooling issues since I bought it 15 years ago. I thought I flushed it well enough and replaced the green coolant after buying it but still had issues. Once I found the block drain petcock I realized how bad things were. It drained what looked like butterscotch pudding, and lots of it. Apparently it settled and plugging block passages. That was surprising since I had already flushed and replaced coolant a couple times and the most recent time it looked like new. I ran it for another season with regular antifreeze, and then replaced the radiator and filled with Fleet Charge. It runs perfect now, with steady temps. Lack of maintenance in the past made it difficult to resolve, but it’s back on track now.
   / Change coolant every 2 years #48
How bout a couple of pics of that 850?
   / Change coolant every 2 years #49
Mixing antifreeze and water is a giant pain, yet I don't feel like spending money on water, as in the premixed stuff. Unless you know how much you are going to need, you always have mixed stuff left over and that means an extra jug on the shelf.
   / Change coolant every 2 years #50
On what to do with old antifreeze, I use a blue plastic 55 gallon drum for mine. When the drums get full I'll find a recycling center to take it. I do that with old engine oil and filters. Have them in 55 gallon drums and a recycler comes by and picks up (sucks out) the oil and gives me an empty drum for the filters, taking the full one. Only requirement is to keep the water out as best I can (hazmat deposition problem for him) and have enough on hand to make a no-charge pickup profitable.
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
2016 Chevrolet Traverse SUV (A59231)
2016 Chevrolet...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
2023 GREAT DANE FLP-0024-00053 53FT FLATBED TRAILER (A59905)
2023 GREAT DANE...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
