ChainSaw Oil-2 cycle
/ ChainSaw Oil-2 cycle #11
Bird
In 1965, when I quit boating, I had about 30 quarts of Quicksilver outboard motor oil left from boating. I'm still trying to use it up in my chainsaws, grass whips, and anything else that takes a gas oil mix. Everything has held up well, no problems.
Bud
/ ChainSaw Oil-2 cycle #12
DO NOT USE OUTBOARD OIL IN YOUR CHAINSAW!
(my caps key was stuck and that is the story I am sticking to!)
Outboard motors are cooled by water and as such they run cooler than a chainsaw or weedwhipper etc. When you get your chainsaw good and hot in the middle of a log and it is hot outside you are asking for trouble. The outboard oil is formulated for use in a more "controlled" environment and breaks down at high temperatures. You are not supposed to use air cooled oil in an outboard either but I can't remember why.
Now a question for those that are braver than me:
If I run out of fuel in the middle if a cut I let my saw cool down before resuming work because I figure it probably got a little too hot when it starved out of gas. Should I just gas it up and go or does letting it sit for a while keep me out of trouble?
/ ChainSaw Oil-2 cycle #13
I don't know whether gassing the chainsaw up and going again immediately would hurt the saw; don't intend to find out either. I'll let mine cool awhile first./w3tcompact/icons/laugh.gif
Oops, sorry, you said that question was for those braver than you, so I don't qualify./w3tcompact/icons/wink.gif
Bird
/ ChainSaw Oil-2 cycle #14
Just to restate an earlier comment a little more clearly, high end chain saws like Stihl and Husquvarna (sp?) require 2 cycle oil specially formulated for high RPM engines. I believe Stihl saws rate in the 14,000 rpm range, while some of the "other" brands can be around 9-10,000.
On the running out of gas thing, emptying a tank when the engine is running at a high RPM is really bad. Especially the high end saws won't forgive you too many times before they sieze.
/ ChainSaw Oil-2 cycle #15
Hi ya
yes stihl husky dolmar etc etc all go up to 14000rpm but you will find that is max rpm non loaded ,working rpm for most saws is around 9000 rpm a chain can only cut up to so many feet per sec then it chokes on sawdust and won't cut .ok as for refueling when hot most books say don't but that is more for fires same as not smoking if you ever pull a saw to bits you will see the head and piston are very thin so there cooling is fast most of the time while you refuel you move sticks ,have a smoke or drink,walk to ya gas and back to the job at hand so in most cases you saw would have cooled abit anyway
catch ya
JD Kid
/ ChainSaw Oil-2 cycle #16
Mike I totally recommend using the factory oil for these saws. I don't know how much you use it or what model you bought but the price of the oil the manufacturer sells is small compared to premature wear from generic oil that doesn't stand up. The diference between the 40 to 50 to one oils is that the one that takes the 50 to one mix is machined better.
/ ChainSaw Oil-2 cycle #17
This is a interesting issue. I used to ride dirt bikes. I mixed 76 premium with Hi-Point oil(per the oil spec), one of the best oils at the time. I had some left over from my ride the day before, and tried to run it in the chain saw. It ran terrible! I ran to the gas station and mixed up some Stihl oil per spec, and the saw ran great!
So, no I stick to Husky or Stihl oil, and mix per the oil spec
RobertN in Shingle Springs Calif
/ ChainSaw Oil-2 cycle #18
The only problem I had was with my LawnBoy 2 cycle lawnmower. Three years ago, to save money, I stopped buying the LB oil and started mixing the oil from the quart (outboard oil) and had the ratio correct (32:1) and the mower would run for 15 or 20 minutes then stop. It didn't sieze. . . it starved (just like it was out-o-gas). This went on for several attempts. Let the thing sit for 10 minutes and it would restart and run fine. Local repair shop said it was a bad ignition module ($60). Part couldn't be returned if it didn't fix it. I didn't buy it.
An old guy that went to our church said to mix a new load of fuel using Lawnboy pre-measured cans and drain the old gas. Said the fixed jets in the carb couldn't handle the viscosity of the outboard oil and would run lean (or rich-I dont remember). Was jetted for lawnboy 32:1 gas oil mix. I did what he said and it worked. (its also called 'low ash' oil)
Now when you look on my lube shelf you will see LawnBoy 32:1 oil, Poulin 40:1 oil (Chainsaw and string trimmer), Mantus 50:1 for the little tiller, all in premeasured manufacturers bottles. Have never had the problems again. All my gas cans are clearly labeled to their use and ratio.
Steve
/ ChainSaw Oil-2 cycle #19
Bird,
They put different additives in the oil for different applications.
As a example, in my Harley, they say do not use car oil; use a oil formulated for a air cooled engine. If one is not available, use oil formulated for a diesel; it has more high pressure, high temp additives. The oil companies have taken many additives out of "car" oil so they dont show up in the emmisions.
For a water cooled 2-stroke, the temperatures the oil operates would differ from those in an air cooled motor, so there will be different additives.
/ ChainSaw Oil-2 cycle #20
Skent, several years ago Consumer Reports, in their testing of the lawnmowers, decided the LawnBoy wasn't a very good mower; not enough power for tall grass. But after buying a new Toro w/Tecumseh engine in '69 that was junk, in '74 I bought a used LawnBoy, changed the spark plug every couple of years, and put new points and condensor in it one time in 15 years. It still looked and ran great when I gave it away when we sold the house. And I have a friend that was still using his after 25 years. I don't know about the new ones, but as far as I'm concerned LawnBoy used to make the best lawnmowers on the market.
Bird
2017 Bobcat 418 (A60462)
2017 Bobcat 418...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
