What oil to fuel ratio are you using?
   / What oil to fuel ratio are you using? #31
One small bottle of 50:1 Stihl oil to 1 gallon of fuel..... Since my fuel can only hold 1 gallon and I buy oil by the 6 pack it hard to make a mistake.... Only have four 2 cycle engines and all are 50:1...
   / What oil to fuel ratio are you using? #32
Ive been using 50:1 for 30 years with no issues. Well, let me restate ….. no problems for last aprox 10 years . Thats when I switched to non ethanol fuel.
Now no problems. I no longer need to rebuild or replace small carbs since swapping to non ethanol.
   / What oil to fuel ratio are you using? #33
Been using the manufacturer recommended 50-1 since the 70’s and it has never caused me any problems.
Have friends that swear 40-1 is a better choice.
   / What oil to fuel ratio are you using? #34
I buy the pre mix bottles for 2 gallons and then pump 2 gallons of gas in the can. I don’t buy the 2 stroke oil in larger bottles to measure and I don’t attempt to pour gas from a larger can. The potential for error is too high for my taste doing it that way. I run everything 50-1 and I’ve never had a problem doing it.
   / What oil to fuel ratio are you using? #35
I don’t use enough all year to mix more than a gallon at a time and I’m willing to pay for the 1 gallon bottles.
If it sits too long I pour what’s left in the can into the 4-stroke mower tank…
   / What oil to fuel ratio are you using? #36
Mix my 2-stroke fuel 1 gallon at a time. 50:1 Echo Red Armour. Have 89 and 90 ethanol free gas available in my area. Also keep Echo Red Amour pre-mixed in quart cans on hand for unexpected needs. Also 50:1 ratio with a 5-year shelf life if unopened, 2 years after opening
Club Car Utility Cart (A55853)
Club Car Utility...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Central Machinery Horizontal/Vertical Bandsaw, S/N 366852447, 120 Volt (A59076)
Central Machinery...
14 Gun Fireproof Safe (New/Unused) (A59225)
14 Gun Fireproof...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
