?chains?
/ ?chains? #21
Jason,
You'll have plenty of traction up from with the FEL. If you're going to use a rear blade, that should give you additional weight on the rear along with the wheel weights. If you're going to be pushing it with the loader, add a ballast box on the 3pt with about 400 lbs in it. You'll be blasting through drifts like a red blurr.
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A59230)
2016 Freightliner...
Kholer Magnum 10 Compressor (A61307)
Kholer Magnum 10...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2025 VR59 Hydraulic Vibratory Roller Skid Steer Attachment (A59228)
2025 VR59...
1987 International 1954 Elliott ECE 3-65H Telescopic Boom Lift Truck (A59230)
1987 International...
