Snow Equipment Owning/Operating Chains for Snow
/ Chains for Snow
HardlyWarcane.....About the weight thing....I will keep the blade on the back and if my snow piles need to be moved with the bucket and rear weight becomes a problem I will attach my CarryAll and find something to add weight.
I just moved a pile of wet loam, probably 4 or 5 yards, with no weight in the back and it was not a problem. Filled the 54' bucket a few times. Ain't it fun.!!
I would say by February 1st I will have good idea of how my JD770 4x4 is going to perform in the snow.
Keep in mind...a pto snowblower is on the short list. Next year at the latest if my money holds up.
/ Chains for Snow #62
I did one winter with my JD X485 without chains. Thought the locking diferential and HDAP tires would make chains unnecessary. Wrong! My driveway has a small incline and when ice is the issue forget going any where without chains. Got me a set and never a problem with them. Would not be without them now.
/ Chains for Snow #63
I live in VT and can throw in a little experience as well. I have a gravel drive that is about 400 feet long. It is sloped from the house up to the road.
Tractor #1 Challenger 28 hp 4wd loaded tires and tire chains. I bought a rear blade. I tried it going forward. Snow piled up so fast I had to go turn around to push it out of the driveway. I tried it going backwards and it worked great. At least until the back pain started... watch out for maintaining an awkward position during operation. Found a deal on an old 8 foot fisher plow. This was mounted on the fel and we tapped in the hydraulics which controlled the curl of the bucket. The inexpensive way to add to the hydraulics, should have used a switch or hooked up to remotes. The plow was a little heavy, but not a safety concern. Large (12" or more snow falls) would push the tractor to either side when the plow was angled. Front tire chains may have put too much torque on things and something will give. Otherwise it worked very well.
Tractor #2 upgraded for BH and a little more capacity. Challenger 33 HP 4wd tires were NOT loaded and started the winter without tire chains. I used a box blade with cinder blocks for rear ballast and the same plow as above. This tractor had two remotes, one to the front and one stayed at the rear. I plowed once with it and ordered tire chains. I could barely make the hill to plow down hill (which was not a problem). Everything worked well with the chains on.
Tracotr #3 upgraded because lost customer support for the Challenger and customer support for Kubota (KX121 and for ON SITE repair of the above Challenger) to include a step in tractor size. We went with Grand L4240 with no BH, toothed bar on the bucket, loaded tires, two rear remotes, and front remote. Also changed from the previous R4 tires to R1 tires. This is where we should have gone to start. The R1 tires were a huge improvement in tractor. I was able to reuse the tire chains from the last tractor (never took them off this summer either). We also picked up a used snow blower for the tractor about 1800 if I recall. Unfortunately it was later in the winter and I only used it twice. But is was great moving snow around the sugar house which had been there all winter. It is almost too easy to just be finished in a couple of passes with no need to push back a bank. I will still use the plow in light snow fall to move the majority of the snow to the down hill side of the drive and then blow it into the field.
Sorry for the long post, but you can see how the weight of the tractors, R4 vs R1, and chains can impact your need. Shop for used tire chains, watch your back with the rear blade, careful when pushing, and look for a deal you cannot pass up on the snowblower. It is worth it and sorry for the long post.
I will have to agree a cab with a front mounted blower would make it too easy.
Mike
/ Chains for Snow #64
I purchased a 2 link set of chains for both the front and rear. I have R4 Industrial Tires and they recommend the 2 link versus the 4 link type snow chains so they do not fall inbetween the bars on the tire. I will install them when the snow really starts to fly and leave them on until spring time. My driveway is mostly flat, but I will be helping out a few neighbors this winter and their driveways are fairly steep. I would rather have them on to avoid a problem during a snow storm :D. I am thinking about getting wheel weights also, not sure if I will purchase the ones you pour your own concrete into or just get the ones that are already weighted? Does anyone have any experience with these? Thanks, KC
/ Chains for Snow #65
/ Chains for Snow #66
@JDGreenGrass - for several years I used my BX24 (smaller than your machine) with R4 industrial tires and a rear blower... no issues - flat drive. BUT several times when I would get out of a blown area into snow of 6-8" or more... traction went away fast. Also trying to bust up drifts with the loader where I needed to push was a FAIL.
So - like others are saying - no chains seems great for blowers but if you are going be doing FEL and blade work - you are going to need every little bit of traction you can muster.
/ Chains for Snow #67
MF Red,
Let me know how the front chains work on your tractor. I have a 2300 & was considering buying front chains also. I stopped because I was concerned about clearance issues.
H2
/ Chains for Snow #68
H2,
I will let you know how they work later, haven't installed either set of chains so far this snow season. Only reason I purchased the front set of chain is to help with the turning performance on ice. KC
/ Chains for Snow #69
I have chains all around on my BX. When the tractor is being used for snow removal it's with the rear blower. I've found that keeping the FEL full of sand helps quite a bit for steering traction. Plus I occasionally use the sand on the 12% hill in the driveway when that gets icy.
/ Chains for Snow #70
If I was you I'd keep looking in 'Uncle Henry's' for used chains or ads for new. That's where I got mine. A FEL is a lot of work for snow removal. Look at a rear grader blade. They work real well and you can angle them in either direction or spin them around and plow backwards ( around $600 for new). If you have much of an incline you can almost always plow down the hill. Plowing up hill on hot top doesn't work real well, even with 4 WD.
Some people get and old plow blade and have mounted on the FEL.
Just food for thought.
/ Chains for Snow #71
We have turfs, so chains were a part of the deal. Will post pics once they are on.
UNUSED WOLVERINE TDB-11-84W-84" BUCKET (A64281)
UNUSED WOLVERINE...
17395SFL (A61568)
17395SFL (A61568)
2019 Ford F-550 4x4 Service Truck (A61573)
2019 Ford F-550...
UNUSED WOLVERINE TREE DIGGER (A64281)
UNUSED WOLVERINE...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
