Chain Saw Advice
/ Chain Saw Advice
I agree on the Stabil.
If you get the two-stroke oil it has fuel stabilizer in it already, but adding a dose of Stabil makes it last a good long time.
I have both small two-stroke and small 4-stroke engines in lawnmowers, pressure washers, generators, etc. For 4-stroke I add a double dose of Stabil, for 2-stoke, the special purpose dyed oil and then a single dose of Stabil.
When gas was 50 cents Stabil seemed expensive. Now that gas is $2.50, $10.00 worth of Stabil treats 80 gallons, and it doesn't seem so bad.
/ Chain Saw Advice #62
<font color="blue"> My words were never meant to start an argument </font>
No argument here,that was not even remotely on my mind. I likewise enjoy talking and sharing experiences here on this particular thread and forum in general. I enjoyed the conversation. I never ever heard of "charring" the ends of the posts,that will be something I will tell my farming friends back here in the Ohio Valley area.
Thanks for the discussion. /forums/images/graemlins/cool.gif
/ Chain Saw Advice #63
I was at a sawmill a couple of years ago and watched logging trucks (Semi's) pull in and be off loaded with a huge payloader grapple thing. The sawmill wanted 8" logs 8' straight & long to fit in the debarker and other production machinery without jamming.
$500 per load to the logger who left with a check.
The sawmill sorted the raw stock and separated board grade hardwoods for a sibling furniture making operation. Other logs outside the size spec went into a 40 acre inventory.
This mill focused on hardwood pallet parts and pallet manufacturing. Their primary goal was xxx board feet per hour production.
To me the interesting points were that the logger was not particularly interested in the type of wood on the truck and the sawmill wanted continuous production and would take furniture grade logs without a second thought to keep the beast fed.
The $140 cord wood supplier said he would come over with his splitter and split for free some Birch my little 15 ton splitter stalled out on. This house has dual fuel forced air wood/fuel oil furnace.
Next time around a corn burner and propane or electric dual fuel might be the ticket.
Anyway back on chainsaws I use 3 Jonsruds around the Farm: a 16" 40cc class and a pair of 65cc that are scary fast.
/ Chain Saw Advice #65
</font><font color="blue" class="small">( I am thinking that it will be a lot safer to notch and backcut most trees only to the point where I can pull them over with the tractor & a 45 foot 3/8" chain. What do you folks think? )</font>
i think ya will be in for a rude awakening the first tree ya pull over with that 45 ft chain, most trees are alot taller than ya would think, i just helped a friend cut down a couple trees saturday that were over 70 ft tall when we measuered them on the ground. they were very close to a his house and leaning towards it, thats why we wanted them outa there since they wernt very healthy, we notched them then put some tension on them with about 150 ft of cable and a snatch block then did the final cut from the backside and everyone went exactly where we wanted it to. on thing to note tho is that we were pulling with my 100 hp 11,000 lbs for tractor, so we had a pretty good advantage on the tree, with a 3000lbs tractor the tree might have been able to overcome the tractor and send it backwards very fast, i saw the aftermath of a for 8N that had that happen, it wasnt pretty
/ Chain Saw Advice #66
Hello! CurlyDave
I spent about a year (last year) looking at chainsaws,lots of info at www.arborist.lawnsite.com Anyway I alway used the cheap boxstore $100 saw so this time I decided to buy one to last. I always heard Stihl was the best and that Husqvarna and Jonsered was a close second but Husky is about $100
or more cheaper for the same size & quality saw. Any of these in the lower priced saw has a high carbon (plastic)
cylinder sleeve,even the $200-250 Stihls.
I chose a Husqvarna 353 that I got for $289, the same in the others would have been $450 or more. there is a Husky 350
that is a really great saw, it still has the (plastic) cylinder but has a metal sleeve,I think around $239 & up. On the site
I mentioned above its 50/50 split but up north I think there were more Husky's then Stihls being used. I really liked the Stihl but honestly couldn't afford it and now that I own 3 Huskys I wouldn't buy any other new saw. I do own 11 saws,
5 Homelites,2 Macs & 1 PoulanPro 4820AVHD & the 3 husky's.
The 353 can use a 16" 18"or 20" the 350 can use a 16" 18"
0r 20" but the 350 is pushing it w/20" You can look at the 350
at Lowes to get a feel for the Husky,both saws weigh about
the same about 3.3 HP and will last forever if maintained right.
If you want to PM or email me I'll give you more site to look at all these saws. Good Luck!! /forums/images/graemlins/grin.gif
/ Chain Saw Advice #67
There is a problem with using a bull rope/chain/cable to guide the tree. Once it begins to fall, all strain on the chain disappears, the tree falls faster than you can keep up. Best you can do is keep it from going the wrong way but forget any idea of guiding it on the way down.
I have resorted to hanging 5 gallon buckets of water in the middle of the cable. That helps but not nearly as much as I had hoped.
Harry K
/ Chain Saw Advice #68
/ Chain Saw Advice #69
My chain saw experiences ...
well, I've bought 3 over the last 10 years. All 16", all "poulan" variants (wild thing, etc). I get the cheapos at costco (or whatever is a local discount box), and pay about $80-$100 each *new*. Sometimes I'll pick up a spare chain for one, or when garage sailin find the same thing with chain and bar for $5. I now have 5 bars, 8 chains, and 2 running powerheads. I take the bucket (5 or so) of dull chains down once a year to be sharpened ($20 aint worth my time to bother sharpening 5-6 chains).
With the cheapo price, and the fact all bars/chains interchange, I never cut with a dull chain, always have a bar and chain to cut free if needed, and always have a saw that'll start with 3 pulls.
In ten years I've probably spent $400 for my "collection", so $40 a year ...
That being said, I could use a 24" saw on occasions, so I expect I'll pick up a used stihl (44 class?) soon ...
/ Chain Saw Advice #70
<font color="blue"> There is a problem with using a bull rope/chain/cable to guide the tree. Once it begins to fall, all strain on the chain disappears, the tree falls faster than you can keep up. Best you can do is keep it from going the wrong way but <font color="red"> forget any idea of guiding it on the way down. </font> </font>
I'd just like to offer my view that it is a properly executed hinge that controls the direction of fall. Again, a good rule of thumb is to have the hinge be about 10% of the diameter of the tree, and the notch cut about 1/4 of the diameter.
Some species hinge better than others, and will therefore allow you to control greater and greater amounts of side lean. Hickory hinges extremely well, with most of the other hardwoods close behind; oak, maple, birch, beech and ash, maybe in about that order. Woods like pine, spruce, hemlock, poplar and willow don't hinge as well, but will still control the tree quite well in cases of back-lean, and to a lesser extent, side-lean.
It is astonishing how well a hinge in a hickory or oak will hold; depending on the amount of side-lean, you can often pull these trees over at up to 90 degrees from their "natural" lean. It is common and advisable to leave the hinge slightly thicker, maybe 15% of the diameter, on the part of the hinge that will be subject to tension forces as the tree is being pulled over (the part of the hinge "away" from the lean).
Of course, if there's a place for the tree to land, almost any tree can be pulled over 180 degrees from its natural angle of lean. The better the species hinges, the more lean can be overcome by pulling directly opposite it; probably as much as 40 degrees. If a tree cannot be felled in the direction of its natural lean, it's always best if you can pull it in the exact opposite direction from its natural lean; but again, a properly executed hinge (in a healthy tree) will do an amazing job of controlling the direction of fall. Experience will tell you when you're asking too much of a hinge.
As always, if you're not pretty darn sure how the hinge will behave, don't attempt the job. And be very aware of the soundness of the tree. Rotted trees do not hinge well AT ALL.
John
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
New/Unused Electric Golf Cart (A61166)
New/Unused...
FLARE STAND (A60736)
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2025 MMS MS36C (A60463)
2025 MMS MS36C...
KJ K2010 20'Lx10'Wx8'H Chicken Coop (A60463)
KJ K2010...
