John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,821
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
</font><font color="blue" class="small">( And I'd just like to put in one more "pitch" for having at least 3 ten-inch or 12-inch plastic wedges in your arsenal. One for starting a neutral or slightly back-leaning tree on its way, and then two more to stack together and drive in if the first one hasn't done the trick. )</font>
I'll second the recommendation for the felling wedges. And get the big ones... 10 or 12" long, as you mentioned, and about as wide as your chainsaw bar. Those little 5 or 6" by 2" wedges are worthless for felling trees (though I guess they're ok for freeing a saw that's stuck in already downed wood that you are bucking up)
I've never had much luck with stacking two plastic wedges. when I tap one in the stack, the other pops out. If I'm VERY carefull, I can get them both to stay in, but then it seems like they always pop when I'm getting ready for what I think is that "one last whack".
I carry two wedges. If I see a tree with significant back lean, I cut a wooden "wedge" as I cut the notch (make my first cut, then a second on eright near it to form my wedge, then make the rest of the notch). I hammer in my 1st plastic wedge, then slip the chunk of wood into the gap and put my next plastic wedge on top of that. Stacking the wood on plastic wedges doesn't seem to pop out the way plastic on plastic does. (For a severe back lean, when I've tapped in my second "plastic stacked on wood wedge", that loosens up my first plastic wedge. I pull it out and put it back in with another, thicker wooden wedge or two. You can tackle some pretty serious back lean this way, and you don't have to carry an armload of wedges, since you make them as needed).
CT Tree Guy - where did you learn your technique? Is it something you just picked up over the years? I had never touched a chain saw until 3 or 4 years ago. I have been playing catch up taking training/safety courses and trying to learn to do things safely, precisely, and with minimal damage to the surrounding trees. I envy the folks who grew up with it. They've usually got a whole lot bigger bag of tricks than I do.
John Mc
John Mc
