Chain hoist advice request
/ Chain hoist advice request #1
gotrocks
Platinum Member
Phenix City Alabama
B-2910 delivered 8/23/01
I'm in the market for a chain hoist. It will get limited use.
I found Grizzly G8704 Chain Hoist - 1 Ton for less than $50
It does not indicate the amount of pull required to lift the 1 ton.
Others I've found list about 77 lbs required to lift the load. But cost more than three time as much.
Please let me have your advice and experience with chain hoist.
Thanks a bunch, (this is not meant to be a chain letter):D
Thank you Gary. I did not notice the specs link. Now if I can get the material sizes needed for the frame I'll be ready to get started. Here is what I plan for my 16 foot tandem wheel flat bed trailer.
I'm thinking 3 in square for the posts and 4x6 for the I beam.
/ Chain hoist advice request #4
I don't know if those sizes will support your planned load, but I'd certainly suggest some diagonal bracing in fore and aft as well as side to side loads. Hate to see it fall apart if you're on a slight side slope. :eek:
Good sized gusset plates might do the job. It would be difficult to brace the rear section with rods in tension and still move a load through.
/ Chain hoist advice request #5
I did the same thing for my shop as well. I did put the end braces on casters though so I could relocate wherever I wanted it. Works like a charm.
Thanks to all for suggestions, here is follow-up. The project is finished, except for making a minor adjustment to the wench to crank the trolly back and forth.
Here's the finished project with the first rock ready to lower on to the bed.
/ Chain hoist advice request #7
Looks good as well as doing the job OK. Glad it all worked out for you. :D
2020 CATERPILLAR 926M WHEEL LOADER (A65053)
2020 CATERPILLAR...
20' One Trip Shipping Container (A66285)
20' One Trip...
Quick Attach Backing Plate (A65579)
Quick Attach...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
2022 Takeuchi TL12R2 (A64126)
2022 Takeuchi...
STEPP SEALCOATING MACHINE (A59914)
STEPP SEALCOATING...
