Caterpillar Diverter Valve
   / Caterpillar Diverter Valve #51
"I like your installation with hard lines at the valves. What do the two valves do? Are those lines stainless?"
Right now, the 2 valves don't do ANYTHING - when the dust settles (eventually) they will control whatever extras I have mounted on the FEL - when the grapple is on, one of them will control that - when the hydraulic sickle bar is on, I already have a flow control for that but the two solenoids will control articulation cylinders on 2 separate joints to change reach and angle - both will be inserted in the bucket curl circuit so I'll have the choice of either curl, articulation 1 or 2.
Yeah, the hard lines are stainless, but those and the mounting plate will need to be re-done, since some dummy mounted the solenoid valves BACKWARD :confused: - trying to keep the solenoids and electrical protected. When it's finished the solenoids will need to be on the opposite end, and I'll fab a shield from 1/4" plate as well as a reversed mounting bracket (duh....)
"Just price 1/2 inch JIC flareless connectors...........at $23.86 each!
27208-08-08 | 1/2" JIC Male x 1/2" Flareless
But the cost of the items seperate, the way you did it, is total....$$5.26. What is the difference? Or am I missing something?"
Yes - for some reason, male JIC's often cost more than females - your link is for a MALE JIC end, and the individual pieces I linked are just the female JIC sleeve with a female nut - they're installed by gently screwing the nut onto a male JIC fitting (with the sleeve INSIDE the nut), then inserting the tubing into both and finally tightening the nut onto the male JIC fitting til the sleeve is crimped onto the tube. IMO, the ones you linked are grossly overpriced so I've used the separate components to make a female JIC, then if you need that end to be MALE, just get a male/male JIC and screw THAT into the tube-mounted female.
In 1/2" size, that male/male JIC adds a whole $1.07, for a whopping total of $6.33 instead of $23.86...
JIC 37° Tube Union (Steel)
If you're just getting into Swage-lok stuff at work, they have VERY specific tightening instructions that vary somewhat with the size - the reason for that is removability - if you don't tighten the fitting ENOUGH, it will leak. IF you tighten it to spec, if won't leak and you can unscrew it and put it back together easily with no leaks.
If you tighten it TOO much, you will upset the end of the tubing that seats inside the fitting too much, swelling it so it won't come out. If you tighten it THREE much :D it's possible to get a stress crack in the fitting body.
These flareless fittings are NOT Swage-lok, but work similarly - with both, you want them tightened just til you can see a SLIGHT deformation where the sleeve fits around the tubing - less, and they'll come apart under pressure; too much, and they can deform and leak.
When I first started using the flareless fittings, I bought a few spares so I could screw up a couple as a learning experience - I found you can get it figured out in 2-3 tries by just paying attention, knowing approximately how much to tighten, and looking at where the crimped sleeve joins the tubing.
Here's a different brand's chart that worked fine for me... Steve
I was in Alvin, Texas today at Tubing & Metric Hydraulics. I love this place because it is just 18 miles from work. I bought two 12 foot lengths of 1/2 inch .065 wall tubing and 4 tube end adapter fittings FL-2000-08-08. The tubing was $4.67 a foot and the "compression" adapter fittings were $11.84 each.
hugs, Brandi
Stress cracks.........reminds me of making AN (JIC) stainless steel flares on lines for DC-9s. Tighten the flaring tool too tight and oops, crack.........start over
Thanks for the instructions.
hugs, Brandi
   / Caterpillar Diverter Valve #54
Brandi, good talking to you tonite - I hope BOTH of us can get life to smile at us a bit more soon :rolleyes:
Just in case you (or others who read this) don't already know, these compression type fittings are NOT like torqueing a bolt - by that, I mean that ALL bolts have a recommended torque spec (except the ones that actually measure STRETCH on the bolt to achieve the required amount of "crush") - but torque specs are DIFFERENT for the same bolt depending on whether it's dry or lubed, and even slightly different depending on what KIND of lube is used -
This is NOT true of compression fittings, which normally use the # of TURNS past a certain point (like when the tube won't move by hand) - dry OR lubed, if they call for 6-1/6 turns (AKA "7 FLATS") then that's what they mean. That # of turns will ALWAYS compress the "guts" of the connector the same amount, whether dry or lubed; so I always use lube (just on the threads, though) so there's less chance of galling on the threads.
Hope this helps... Steve
Steve,
What do you lube the threads with?
hugs, Brandi
The air intake hose came in today. Here it is with the air filter assembly raised 2 inches.CAT Air Intake Hose Installed.jpg
Also the hoses from Discount Hydraulic Hose came in. Here is the relief filter to tank line installed.CAT Filter To Tank Line Installed.jpg
hugs, Brandi
   / Caterpillar Diverter Valve #57
Lookin' good Brandi, I like your work -
"What do you lube the threads with?"
sometimes if it's a fitting I'm likely to rub up against, I'll just use a little Tri-Flow (not as obvious on your shirt :rolleyes:) - otherwise it's a light coating of Never-Seize, I find the fittings don't argue so much when you need to take 'em apart after a few heat/cool cycles... Steve
This is what we used on piston powered airplane spark plug threads. LOCTITE C5-A Copper Anti-Seize - Loctite
A little dab would do you.
hugs, Brandi
   / Caterpillar Diverter Valve #59
Yeah, I might even still have some of that around - we used it on 50,000 amp water-cooled buss bars for vacuum arc melt furnaces - every thing on those was copper, right down to nuts/bolts/washers/lock washers that bolted the sections together - the "never-seize" I referred to earlier is actually Chesterton's high nickel anti-seize, good for both steel and stainless steel fasteners - been using the same can for maybe 10 years now, good thing it doesn't go bad if you keep the lid on tight :laughing: ... Steve
I wanted to give my local hydraulic shop some business during this installation project.:) So I let them build two 3/4 inch hoses with BSPP fittings. I got up early Monday to do this. I told them I needed two 24 inch lines. He handed them to me (made while I waited) and I paid for them, while my mind was screaming....................they look short.:eek:
Got them home and a quick dry fit told me my mind was right.:shocked: Instead of 24 inch lines, I needed 42 inch lines.:mad: So I got a male union fitting ($11):mad::mad: to use what I had for one line. That didn't work either because I need a huge bend right where the union is.:eek: So I ordered, from Discount Hydraulic Hose, both lines of 42 inches, for $40 less than my local shop.:ashamed:
No wonder engineers make so much money...........guess they get more sleep!:thumbdown:
hugs, Brandi
2003 650 Kawasaki (A53314)
2003 650 Kawasaki...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
Rain-Flo Vegetable Transplanter (A53314)
Rain-Flo Vegetable...
20'x12' Livestock Metal Shed (A53316)
20'x12' Livestock...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
