Cat1 3ph question...
/ Cat1 3ph question... #1
smokedtires
Lysander NY
I stopped by a local Tractor Supply Co to look at their box blades. They recommended a King Kutter XB box blade that fits category 1 tractors with category 0 spacing. Now I'm not sure if this would be correct or not for my JD 4100, any suggestions will really help. How do I know if my CUT has a 1 or 0 spacing or does it not really matter?
Thanks.
/ Cat1 3ph question... #2
You will have no problems with the boxblade for the 4100, it's bigger than mine and I could hook up to that one.
/ Cat1 3ph question... #3
I also have a 4100. I have a Kubota 48" box scraper I use with it. My 4100 has the R4 industrial tires, which can only be placed in the narrow position and I have a problem with the tires scraping the 3-pt arms with the box scraper attached. I don't have this problem with my King cutter rear blade though. The pin spacing on the Kubota is 27" I think.
/ Cat1 3ph question... #4
My 4010 is Cat 1; your 4100 has to be. Cat 1 is 26" wide at the lift arms.
I've a Frontier back blade on my 4010. Bought it from the dealer for $250. It also has pins on the inside for Cat 0 machines.
Ralph
Great, it looks like the XB should work then. I just wasn't sure about the Cat 0 spacing. Thanks /forums/images/graemlins/smile.gif
Kubota V3300-T Turbo Diesel Industrial Engine  84 HP  Pump Takeout (A63689)
Kubota V3300-T...
John Deere 1770 Planter (A63111)
John Deere 1770...
9 SHANK CHISEL PLOW (A63291)
9 SHANK CHISEL...
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
2002 Ditch Witch 1230H Walk-Behind Trencher (A61572)
2002 Ditch Witch...
2025 Intersate Fabrique 12' x 6' Dump Trailer (A62613)
2025 Intersate...
