Cat III quick hitch
/ Cat III quick hitch #2
Welcome to the forum.
Here are some specs
/ Cat III quick hitch #3
I have one on a 440 AC tractor but it may be class 4 not sure,--probably could measure it and see what size material its made from,---two guys cant lift it to hang it on the 3-pt arms, so its made from some thick stuff. thanks; sonny580
Hey,
Thanks for your reply. I'm needing the thickness of the metal used, (I'm presuming that most of these are made of square or rectangle tubing). I found a lot of different makes on the market and got some specs but not the thickness of the main structure.
Thanks for any help you can give.
Scarbrough
/ Cat III quick hitch #5
I built one years ago out of 4x4x3/8 square tubing. I used 1&1/2 inch plate for the hooks it spent about 15 years on the back of a 150hp MF now its on a 1486 IH. Never has bent or twisted
211298 (A62131)
211298 (A62131)
2022 Bobcat T770 (A64126)
2022 Bobcat T770...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
2015 Case TR320 (A64126)
2015 Case TR320...
