3-Point Hitch CAT II Three Point
/ CAT II Three Point #1
OldDirt
Eastern NC
Kubota L3130
Newby question here, can implements (bush hog box blade, etc) designed for a CAT I three point hitch be adapted/modified to fit a CAT II three point hitch (MF 285)? Or can the CAT II hitch be adapted/modified to use the CAT I implements? Is the CAT II PTO shaft different? Thanks in advance for your help/patience.
OldDirt
/ CAT II Three Point #2
Most all CAT II tractors can use CAT I implements with the use of bushings or different hitch pins and possibly moving sway blocks/sway chains or bars. CAT I is designed for 50 hp and lower. CAT II is 50 HP to 100HP. Implements designed for CAT I can fold like a tent if too much force is applied. CAT II implements are generally too wide to convert to use as CAT I with some exceptions. A good many implements that are sized for 40 to 60 hp applications are built to accomodate both catagories.
/ CAT II Three Point #3
The pto shafts are not related to the hitch size but as to the horsepower needed to run the implement.
/ CAT II Three Point #4
I've got an 8 foot Cat II blade mounted on a Cat I MF 2135. I bought 2 lower link Cat I pins with the Cat II thread and mounted them inward. Also on some of the Cat II tractors like John Deere the 3 point can be converted to Cat I and then use bushings on the pins. That way you can run a Cat I post hole digger, etc.
/ CAT II Three Point #5
OldDirt
I have one cat-II tractor and two cat-I tractors and most all of my implements are cat-I. All of the cat-I implements work on the cat-II tractor using bushings you can purchase at Tractor Supply Corp (TSC).
Thanks Sunnyside/all!
OldDirt
2004 John Deere 8320 (A63688)
2004 John Deere...
2017 INTERNATIONAL LF687 DAYCAB (A65643)
2017 INTERNATIONAL...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
Sterling AT (A63689)
1998 Chevrolet C7500 Dump Truck (A62613)
1998 Chevrolet...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
