Cat 2 Quick hitch with Cat 1 implements - possible???
   / Cat 2 Quick hitch with Cat 1 implements - possible??? #1
Doug McConnell
I have a cat 2 tractor and just purchased a speeco cat 2 quick hitch. I also have several cat 1 implements: bush hog, box scraper blade and tiller. Given that the cat 2 quick hitch is wider than the cat 1 implements, do they make an adapter (i.e. longer pins) that I can put on my cat 1 implements. I know I can buy the adapters that change the pin diameter (and have bought a set for each cat 1 implement), but wonder if they also make the longer adapter pins. Any suggestions would be greatly appreciated.
   / Cat 2 Quick hitch with Cat 1 implements - possible??? #2
Tractor Supply has lift pins (draw pins) with a nut where the typical shoulder is. That way you can make it stick out farther. Not sure if will work for what you want.
CountyLine® Draw Pin, Cat 1, S070202TSC - Tractor Supply Online Store
TS also has the same thing in CAT 2 but twice as expensive.
CountyLine® Draw Pin, Cat 2, Adjustable, 1-1/8 in. dia. - Tractor Supply Online Store
You may have to re-engineer the CAT 1 implements to get them to line up. That is, if you weld. Just leaving the pins sticking way out would put a lot of strain on the implement and the pin.
I prefer the Pat's Easy Change system because so many of my implements have variable widths. Some are homemade.
   / Cat 2 Quick hitch with Cat 1 implements - possible??? #3
This subject is something I am wondering about as a newbie.
My l5460 can do cat I or II and so far all my implements have different width lower pins to accomodate either.
But as I am getting more implements and swapping more often, I am thinking about getting a QH (maybe a land pride). But would hate to get a cat I qh as it can do away with the advantage of the cat II pin positions.
But then I have to take the qh off when using implements that are cat I and aren't cat II compatible. Like how the Wallenstein bx62s shipper looks to me. That does away with lots of the advantage of a qh....
   / Cat 2 Quick hitch with Cat 1 implements - possible??? #4
The Priefert quick hitch is adjustable for Cat 1 and Cat 2.
Quick Attach
Bruce
   / Cat 2 Quick hitch with Cat 1 implements - possible??? #5
It says for cat II needs tractor adjustment whatever that is. And says for cat II, cat I sized pins are still required.
If I am reading correctly.
Takeuchi TB016 (A53317)
Takeuchi TB016...
2004 CATERPILLAR 320C L EXCAVATOR (A60429)
2004 CATERPILLAR...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2018 CATERPILLAR 242D SKID STEER (A60429)
2018 CATERPILLAR...
TANK MANIFOLD (A58214)
John Deere 1025R (A53317)
John Deere 1025R...
