Toplink Cat 2 pto
/ Cat 2 pto #1
Walkin Horse
Platinum Member
Chesterfield Va
Shibuara Ford New Holland 555D NH Workmaster 55
How much bigger is a cat 2 pto vs a cat 1. Can you get get an adapter to change it with out buying a new driveshaft.
/ Cat 2 pto #2
Are you asking about the upper link, the drive shaft or the tractor's stub shaft?
The upper link pin diameter is 3/4" on a Cat 1, 1" on a Cat 2. You can use a 1/8th inch (wall thickness) bushing for that.
Here's a link to review...then you can clarify your question:
TractorData.com - Power Take-Off Types
/ Cat 2 pto
The pto shaft. I got the bushings from the dealer. I went to hook my finish mower up and the splined shaft is bigger than the driveshaft. Do they make an adapter without buying a new shaft.
/ Cat 2 pto #5
They carry adapters, but unless you've got something goofy, all 540 PTO shafts should be the same. Are you trying to use a 1000 rpm implement on a 540 rpm PTO?
/ Cat 2 pto #6
What kind of finish mower? Are you sure it doesn't have an older 1 1/8th inch input?
/ Cat 2 pto #7
1-3/8" 6 and 21 spline are std up to the big tractors. After that ?100+HP? they go bigger to prevent twisting off by huge peak loads. Im not familiar with True transition point or the precise step up in size.
larry
/ Cat 2 pto
larry
I went back just now with nothing in the way and just the tractor half of the driveshaft. I slid it right on. Good now I can get to mowing.
I guess the other nite I had spent about two hours hooking up freeing everything up from leaving it sitting and getting the flat tires fixed. I guess I didn't try real hard to get it on.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
Yamaha 150 V6 150 2-Stroke (A66738)
Yamaha 150 V6 150...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
DRAGON 500BBL WHEELED FRAC TANK (A67714)
DRAGON 500BBL...
2012 DIAMOND T TRAILER GOOSENECK TRAILER (A67714)
2012 DIAMOND T...
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
