Case IH D40 hard start
/ Case IH D40 hard start #11
Why don't you try the basic test? Remove the signal wire from the starter. Put a short jumper wire on the spade and "jump" that to battery positive. Do that a few times. Do you get the same result as with starting (or attempting to start) with the key? If yes, then you have a starter, battery, cable, or related problem. On the other hand, if the starter engages and cranks the engine first time every time, the problem is with the incoming signal circuit.
Incoming signal issue. Guess I get to build the starter relay. Sure will save a lot of aggravation. Seems like an easy build. Anything to watch for? Thank yall for your help.
/ Case IH D40 hard start #14
Pretty straight forward. Have done it a number of times. Plenty of instructions out there. Just stay away from the three dollar relays. Get one you can count on.
/ Case IH D40 hard start #15
I would start with cleaning the battery terminals. Then disconnect the signal wire like stated above.
My tc40 died on me climbing a pile of dirt a few weeks ago. Stone dead, nothing for power. Turns out the battery terminals where just dirty. Parked undercover also. Cleanes the terminals and replaced the rusty original terminal bolts with stainless steel.
CATERPILLAR 279D3 SKID STEER (A62129)
CATERPILLAR 279D3...
2014 Ford F-250 Ext. Cab Service Truck (A59230)
2014 Ford F-250...
2019 Big Tex T/A 16FT Utility Dump Trailer (A59230)
2019 Big Tex T/A...
2012 International (A59230)
2012 International...
CAT B30 HYDRAULIC HAMMER (A60736)
CAT B30 HYDRAULIC...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
