Ford 1710 will crank but not start
   / Ford 1710 will crank but not start #31
HI Grateful4,
I think it is nowhere any kind of electrical problem. The engine is cranking, just maybe needs fuel (or at the right time). Here are two videos of my 1710 starting. I think the preheater does not work any more, or does not get red for at least a minute or more. Heck with it, starts just fine.
Ford 1710 Tractor Cold Start - YouTube is a start with the tractor cold. Maybe 70 degrees F.
Ford 1710 Tractor Warm Start - YouTube is a start after a few minutes of warming up.
Looking forward to your progress.
Eric O
   / Ford 1710 will crank but not start #32
Hello,
I recently bought a 1710 and it is also hard to start, it does put out heavy black smoke when turning over. Did you ever find the problem with yours?
Phil
Hello,
Phil
Yes, I sold the tractor actually to a guy with 4x4 1710 and a blown engine. He has a shade tree mechanic friend. It was a compression issue, the engine needed to be rebuilt.
He replaced a bad rod, bearing, rings and gaskets. He spent 25 hard hours and a lot of time on the cylinder with emery cloth. The engine runs like new for now but will need work again in the future I'm sure.
So if you have to pay someone to repair the engine... you're looking at quite the expense. This model tractor was absolute garbage! I had so many people call wanting a "good engine" because their engine was toast. It's like many Ford model tractors or vehicles... Fix Or Repair Daily. There are some great models out there but this isn't one.
Hope that helps!
   / Ford 1710 will crank but not start #34
Hope that helps!
Yes, Ill check the compression.
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
CAT 930M (A58214)
CAT 930M (A58214)
2013 Ford Taurus SEL Sedan (A56859)
2013 Ford Taurus...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
McFarlane 4025 Reel Disk (A59814)
McFarlane 4025...
