Case 580E Backhoe
/ Case 580E Backhoe #1
BQZ
Case 580 E
Have a CASE 580 E Backhoe (model :Super E)that won't go forward ,got reverse no problem all the arms and buckets working fine just no forward
Here's what I've done so far :
1)checked linkage(seems to be ok).
2)check hydraulic fluid (full).
3)Drained fluid and replaced with new.
still won't go forward any ideas?
/ Case 580E Backhoe #2
There's a hydraulic shuttle valve located at the bottom of the linkage. If I remember correctly, upper right side of trans, remove floor pan to access. Probably your culprit and not too pricey either.
/ Case 580E Backhoe
I'll check it out
thanks for reply:)
/ Case 580E Backhoe #4
I know this might sound dumb, but my Dad was on my backhoe and he said the same thing. It just stoped on him and wouldn't go forward. I asked if it went in reverse, and he didn't know. He went and checked, and it didn't.
He said he didn't do anything to it, but it just stoped moving.
When I got out there, I looked for a hydraulic leak first, but didn't see anything. But I did notice that the drive shaft was off. It had sheered the bolts that attach it to the transmission.
Other then that, I don't have a clue.
Good luck,
Eddie
/ Case 580E Backhoe #5
Hi All we Do Case Genuine Spares with Doorstep Delivery Worldwide. Anyone in Need can reach us. We do Genuine, OEM, Aftermarket, New and Reman Both.
You can Reach us at
Home - Fluid Power System Technologies
Snap-On Southern Thunder Edition 24-drawer tool box (A63689)
Snap-On Southern...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2007 DRAGON  130BBL VACUUM TRAILER (A65643)
2007 DRAGON...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
