Can I make 3 point back blade go higher?
/ Can I make 3 point back blade go higher? #1
Deepdrop
Lebanon, New Hampshire
Kioti CX2510 (2021)
Hi all,
I recently bought a back blade to use mostly for snow but also for dirt this summer. I've been disappointed to find that the blade keeps catching on things because I can't raise it high enough off the ground.
I was thinking that maybe I could replace the left, non-adjustable lift arm on the 3 point hitch with one that is adjustable. I don't know if there is any reason this would not be a good idea, or if it would even work at all.
I couldn't find much on this topic online, but I was hoping I might get some ideas on this forum. Thanks,
Daniel
/ Can I make 3 point back blade go higher? #2
can you put the top link in the upper hole?
Most of the gain in lift will come from the length and position of the top link/
/ Can I make 3 point back blade go higher? #3
On many tractors, the lift arms have different holes to adjust lift height. Check and see if your tractor does.
/ Can I make 3 point back blade go higher? #4
I don't believe altering tractor is a good idea,alter blade instaed.
Dropping hitch pins lower on blade will result in raising blade higher. You might also have to drop top link attachment point on blade. If you have a torch and welder it should be simple. You could also mock it up with bolt-on first to make sure it works like we think it will then weld in place.
/ Can I make 3 point back blade go higher? #5
The INBOARD end of the Top Link pins into hole pairs.
Your tractor may have 2-3-4 pairs of holes for the INBOARD attachment of the Top Link.
Pinning the Top Link into the LOWEST pair of holes will give your earth moving implements maximum adjustment range.
/ Can I make 3 point back blade go higher? #6
Your toplink can be shortened quite a bit yet, that will raise the blade a lot.
You can also vary which top link hole on the tractor you use and see if that changes anything.
/ Can I make 3 point back blade go higher? #7
Moving the top link to the bottom hole on the tractor side, will raise the blade when you lift the 3 pt. Also, looks like there is another set of holes on the lift arms that you can use. Move the side links to those holes and give it a try. Should lift quite a bit higher.
/ Can I make 3 point back blade go higher? #9
You have a few places you can change for a higher lift. Move the 3 point arms out (up arrow). Use the lower toplink hole (right arrow) or move the toplink connection to the blade (left arrow).
Adjust all three and I think the blade might hit you on the back of your head :ROFLMAO:
Seriously, getting the blade to lift that much will reduce the angle that the blade can bite into the ground and be much less aggressive (not be able to cut into the ground).
Thank you all very much. I spent a fair amount of time trying to figure out what the various adjustments did in terms of raising the blade. From what I could tell, the only adjustment that would actually raise the blade higher was to somehow shorten the lift arm. So I did try using the upper hole at the bottom attachment of the lift arm. This didn't seem to make much difference. And from the replies I got, it sounds like I was wrong anyway....
I will play around with different top link configurations, and also maybe the lift arm holes.
Also, I'm not sure I used the proper terminology. I'll watch the videos to be sure.
What I am calling the "lift arm" is the piece I drew arrows to the top and bottom of, on the picture on my initial post.
To "old and tired", thanks for the suggestions. What do you call the part that your UP arrow is pointing to? Is that the lift arm?
Thanks everyone.
/ Can I make 3 point back blade go higher? #11
....What do you call the part that your UP arrow is pointing to? Is that the lift arm?
Yes, that is the lift arm. There is a hole that the arrow is pointing to. You disconnect the up and down linkage, and connect them further out on the arms. You lose the ability to lift more weight but you can lift it up higher.
For the other adjustments; Where the toplink (the adjustable screw) attaches on the back of the tractor, there is 3 holes, attached it to the bottom hole. On the implement side, you'll have to unscrew / lengthen the toplink to reach the top / upper hole on the implement. Now you can screw the toplink "in" to shorten it, which will lift the blade in the air more.
/ Can I make 3 point back blade go higher? #12
I'll be interested if it works at all for that. Folks I know say no way.
I don't see a reason why not.
However, I think you might benefit from using the upper hole in the upper portion of that county line read blade. That should lift it up plenty.
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2017 Ford Transit Connect Cargo Van (A59230)
2017 Ford Transit...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
Chemical Containers Tank (A57148)
Chemical...
GEARMATIC WINCH (A58214)
GEARMATIC WINCH...
(INOP) MASSEY FERGUSON 1552 TRACTOR (A59823)
(INOP) MASSEY...
