old and tired
Yes, that is the lift arm. There is a hole that the arrow is pointing to. You disconnect the up and down linkage, and connect them further out on the arms. You lose the ability to lift more weight but you can lift it up higher.....What do you call the part that your UP arrow is pointing to? Is that the lift arm?
For the other adjustments; Where the toplink (the adjustable screw) attaches on the back of the tractor, there is 3 holes, attached it to the bottom hole. On the implement side, you'll have to unscrew / lengthen the toplink to reach the top / upper hole on the implement. Now you can screw the toplink "in" to shorten it, which will lift the blade in the air more.
