BX23MLB Fluid Volumes
   / BX23MLB Fluid Volumes
Thanks! It's cleaned up and back in for about a week now.
   / BX23MLB Fluid Volumes #12
Also, when doing the oil change on the front differential I thought the manual said it would take more than 4.5 litres of 80w90 oil. I put in three litres and it was way over full so I ended up draining out 1/2 of a litre and it appears to right on the mark after driving it on a couple of short runs.
If that '23 is anything like my BX 24 there are breather plugs on the outboard ends of the front axle. If you don't pull them it won't allow a proper fill. (Don't ask me how I know...)
Z.
Z.
Thanks, I'll have another look for the plugs. This little machine has never been pressure washed in its 1862 hours of run time so I might of missed them.
   / BX23MLB Fluid Volumes #14
Where the heck did you find that filter? I have 700 hours on mine and the hyd FEL us getting tired. Mayb checking this filter will help
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56436)
Dual Tailwheel...
2015 MACK GU713 DUMP TRUCK (A59823)
2015 MACK GU713...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
43055 (A55851)
43055 (A55851)
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
