BX23 front wheels
/ BX23 front wheels #1
2006LJRubicon
Kubota B2400 and Kubota BX23
I was wondering if anyone knew if the the front wheels off a BX25 would fit the BX23? The BX23 are 18X850X8 and i believe the BX25 are 18X850X10.
Thanks
Mark
/ BX23 front wheels #2
Thanks
Mark
The total diameter and gear ratio result is the same. Kubota went to a "low profile" look on the BXs a few years back, with larger wheels, but lower profile tires, so it all comes out in the wash.
/ BX23 front wheels #3
The extra width might be an issue for MMM anti-scalpe wheel clearance, otherwise, I don't see any issues.
/ BX23 front wheels #4
You can normally balance front to rear diameter with air pressure on near same size changes of tires. We have found that they vary within a size from brand to brand!
After installation you can check the ease of disengagement of the four wheel drive after driving on a hard surface. There are times with some tires you can see if you have lead or lag by the foot print. To pick the front end up with a loader you can see the front tires spin with lead or lag. A loaded bucket on the loader changes the lead to a lag quickly when the tires are squashinng from the load.
/ BX23 front wheels
does n e one know the bolt pattern? is it 70mm or 90mm?
/ BX23 front wheels #6
*Kubota went to a "low profile" look on the BXs a few years back, with larger wheels, but lower profile tires, so it all comes out in the wash.
*If He puts the BX25 front rims on a BX23 He will no longer be able to use R1s on the BX23 .
What's his logic for switching rims anyhow?
*The extra width might be an issue for MMM anti-scalpe wheel clearance, otherwise, I don't see any issues.
*Both are the same width 8.50.
The issue is R1s won't fit the BX25 rims.
/ BX23 front wheels #7
I have the later BX 24 front rims and tires on my BX 23...
The reason... I had a front tire bubble and pop... the cost to replace the one tire with something similar was more than 2 new tires mounted on rims from Kubota Whole Goods.
So far, have not noticed any problems shifting from 2 to 4 and vice-versa.
2014 Chevrolet Camaro (A62613)
2014 Chevrolet...
4004SFL (A59228)
4004SFL (A59228)
ATS ATS-PC90 Heavy Duty Plate Compactor (A62679)
ATS ATS-PC90 Heavy...
2018 Deere 650K LGP (A64127)
2018 Deere 650K...
DRILL CABINET SKID (A60736)
DRILL CABINET SKID...
2008 Kaufman Wedge Trailer (A62613)
2008 Kaufman Wedge...
