BX23 front wheels
/ BX23 front wheels #1
2006LJRubicon
Kubota B2400 and Kubota BX23
I was wondering if anyone knew if the the front wheels off a BX25 would fit the BX23? The BX23 are 18X850X8 and i believe the BX25 are 18X850X10.
Thanks
Mark
/ BX23 front wheels #2
Thanks
Mark
The total diameter and gear ratio result is the same. Kubota went to a "low profile" look on the BXs a few years back, with larger wheels, but lower profile tires, so it all comes out in the wash.
/ BX23 front wheels #3
The extra width might be an issue for MMM anti-scalpe wheel clearance, otherwise, I don't see any issues.
/ BX23 front wheels #4
You can normally balance front to rear diameter with air pressure on near same size changes of tires. We have found that they vary within a size from brand to brand!
After installation you can check the ease of disengagement of the four wheel drive after driving on a hard surface. There are times with some tires you can see if you have lead or lag by the foot print. To pick the front end up with a loader you can see the front tires spin with lead or lag. A loaded bucket on the loader changes the lead to a lag quickly when the tires are squashinng from the load.
/ BX23 front wheels
does n e one know the bolt pattern? is it 70mm or 90mm?
/ BX23 front wheels #6
*Kubota went to a "low profile" look on the BXs a few years back, with larger wheels, but lower profile tires, so it all comes out in the wash.
*If He puts the BX25 front rims on a BX23 He will no longer be able to use R1s on the BX23 .
What's his logic for switching rims anyhow?
*The extra width might be an issue for MMM anti-scalpe wheel clearance, otherwise, I don't see any issues.
*Both are the same width 8.50.
The issue is R1s won't fit the BX25 rims.
/ BX23 front wheels #7
I have the later BX 24 front rims and tires on my BX 23...
The reason... I had a front tire bubble and pop... the cost to replace the one tire with something similar was more than 2 new tires mounted on rims from Kubota Whole Goods.
So far, have not noticed any problems shifting from 2 to 4 and vice-versa.
HITACHI EX550LC EXCAVATOR (A58214)
HITACHI EX550LC...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
2022 CATERPILLAR 299D3 XE SKID STEER (A62129)
2022 CATERPILLAR...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
